#1 (permalink) |
i was wondering if anyone knows what the torque specs are for the connecting rod caps. i had to rebuild my engine and i lost the piece of paper with the torque specs. I have a 1995 base 3000gt.
Thank you very much, Aaron
1995 3000gt Base, Just completed my engine rebuild and MTX swap
![]() Mods: Long tube headers, 2.5" Magnaflow high flow cat, 2.5" single in dual out Flowmaster 40 series muffler, true cold air intake, throttle body spacer, upper plenum spacer, stage 3 heads, Underdrive pulley, Short throw shifter and more Ext. Mods: HID headlights, 20% black window tint, 18" black w/chrome lip rims, 245/40/zr18 low profile tires, 2 3.5" chrome exhaust tips Int. Mods. Jenson in-dash DVD player, Alpine 12 sub, Alpine amp, blue lights |
#5 (permalink) |
wait the way i worded my last question was kind of confusing, sorry. The first question i asked was what the torque settings were suppose to be on the connecting rod caps, you said 14 ft/lbs.
my second question was are the torque settings for the cradle/ main bolts suppose to be 67 ft/lbs? Sorry for wording it in a confusing way. |
#6 (permalink) |
***** User
Ok lets start over. I deleted my last posts to avoid confusing because apparently my brain doesnt want to work right...Hopefully these ones help you out better
![]() cam bearing caps: Front and back bearing cap 14 ft-lbs 2,3,4 bearing caps 8 ft-lbs Connecting rod cap nut: 38 ft-lbs Bearing cap bolts: 67 ft-lbs ![]() Connecting rod caps are supposed to be MUCH more than 14 ft-lbs. The 14 ft-lbs i gave you earlier was for the cam bearing caps in the heads, so you can just ignore those seeing as thats not what you asked me. ![]() |
