Old 04-09-2008, 06:21 PM   #1 (permalink)
playinwitmatchz is an unknown quantity at this point
Default timing belt question
ok, what are the chances of having to replace pistons and/or rods when the timing belt goes? I know i will be replacing anywhere between 1 and 24 valves or just getting 2 used heads, but would i need to drop the cash for a set of pistons too?
playinwitmatchz is offline   Reply With Quote
Old 04-10-2008, 08:42 AM   #2 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
Default Re: timing belt question
Typically not, but you can make that judgement by how big any dents in the pistons are.
-SP
One of 789
Old 04-10-2008, 10:07 AM   #3 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3JeffWVR4 Level 3
I've rebuilt several engines with from 2 to 12 bent valves due to jumped timing, and have yet to see any piston or rod damage as a result.
Jeff W.
Red '92 VR4 213,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, 1/4 mile at a time, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, DR Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, PwerStop/Stillin rotors, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi wheels, 2-tone all-leather Interior.
JeffWVR4 is offline   Reply With Quote
Old 04-16-2008, 07:33 PM   #4 (permalink)
jlfx car audio's Avatar
Drives: 97 3000gt sl
jlfx car audio is an unknown quantity at this point
what would be a good timing belt for a sohc is a autozone belt ok or do i need a mitsu.. belt
autozone is like 40-70
napa is roughly 60-100
mitsu is like 130
is their any diference?
is is a stock motor (NA sohc)
jlfx car audio is offline   Reply With Quote
