Old 05-07-2008, 09:21 AM   #1 (permalink)
shadow24v is an unknown quantity at this point
Default spun bearing?
I have a SOHC 24v 6g72 motor
ok, i was at the dragstrip last friday and i blew the oil pressure sender out of the filter mount. I was running close to 100psi pressure at 6000rpms. i thought i shut it down fast enough, but apparently i didnt. My lifters are a bit louder (after quieting down from new oil) than before and i have a clunk from the pully side of the bottom end. i cant tell if its a rod bearing or main bearing thats gone because it seems to go away when you rev the motor. anyone have any ideas?
Blowout
Clunk
shadow24v is offline   Reply With Quote
Old 05-10-2008, 06:32 AM   #2 (permalink)
Default Re: spun bearing?
*bump* Anyone?
Old 05-10-2008, 06:56 AM   #3 (permalink)
nylander's Avatar
Drives: '93 R/T NA, '02 WRX
nylander is an unknown quantity at this point
Is there any metal in the oil?
K&N FIPK #16 - Intrax Springs - 3sx downpipe - Test-Pipe - Borla Cat-back - 99 lifters - Vr-4 replica rims
nylander is online now   Reply With Quote
