Old 04-19-2008, 11:29 AM   #1 (permalink)
houska is an unknown quantity at this point
Default SOHC Exhaust ideas.....sound clips...questions
Ok before you say anything, i know i have a sohc LOL. but anyways im looking for a good sounding custom setup for a sohc. but how differnt are the sounds of a dohc and a sohc.
B/C i have heard several dohc sound clips and was just wondering if the sohc sounds simular. Also if you do have a sohc please tell what your setup is, thanks
please excuse my ignorance.
houska is offline   Reply With Quote
Old 05-03-2008, 10:59 AM   #2 (permalink)
Senior Member
speed3000gt's Avatar
Drives: RT|TT
speed3000gt Level 1speed3000gt Level 1speed3000gt Level 1
Default Re: SOHC Exhaust ideas.....sound clips...questions
How obnoxious are you looking to go? There are always the ricer fart cans you can install but they don't sound good. Some people get the right sounding note with Magnaflow. I have RT/TT cat back on my SOHC and it sounds throaty but not loud... I don't know if you've ever heard a turbo 3/s's exhaust, but thats what it sounds like.
I'll try to get a clip if not.
Elvis has left the building
speed3000gt is offline   Reply With Quote
Old 05-03-2008, 12:50 PM   #3 (permalink)
steellittledude's Avatar
Drives: 1992 red sohc 3.0
steellittledude is an unknown quantity at this point
I too have an sohc that i'm redoing the exhaust on because it needs to be. I don't have a big budget, so I was just going to get a universal cat, then bend and lay a bunch of 3" pipes to fit and end it with the flowmaster 40. What do other sohc drivers have?
steellittledude is offline   Reply With Quote
Old 05-03-2008, 01:01 PM   #4 (permalink)
ImNotSpeeding's Avatar
Drives: 97 3000gt
ImNotSpeeding is an unknown quantity at this point
3 inch pipes on a sohc? are you guys outta ur mind?
what spec is your car? i know with my cali spec..due to the 2 precats and main cat.. my car is still somewhat quiet.. even with my 3sx downpipe and custom striaght pipe cat back..
and are you looking for power or sound? because i had a tt borla 3inch catback on my car for a while..sounded nice..quieter then the 3inch on n/a dohcs(im guessing due to the cali spec) but i lost power due to no back pressure
97 Green 3/s: 3sx downpipe/Maximal Test Pipe/Custom Cat back exhaust/Ebay Intake/KYB-GR2 Struts/Ground Controls
ImNotSpeeding is offline   Reply With Quote
Old 05-03-2008, 01:09 PM   #5 (permalink)
what would be the best means of acquiring the most power, then?
Old 05-03-2008, 01:09 PM   #6 (permalink)
Drives: 91 Stealth base
Trader Rating: (16)
91Stealth89 is an unknown quantity at this point
Heres, mine, I only got a shitty sound clip right now, but needless to say, Im not all that impressed with how it sounds, I guess I just dont like the SOHC's sound, its here for your referance though, setup is 3SX DP, testpipe 2.5" catback glasspack for a res.
-Ian
SOHC Stealth Exhasut Vid 1 - Video
91Stealth89 is offline   Reply With Quote
Old 05-03-2008, 01:11 PM   #7 (permalink)
Drives: 97 3000gt
for more power use 2.5 inch piping
and refer to this thread if you want sound clips:
http://www.3si.org/forum/f60/sohc-exhaust-clips-415357/
Old 05-03-2008, 01:13 PM   #8 (permalink)
Drives: 97 3000gt
91stealth do you have precats?
Old 05-03-2008, 02:25 PM   #9 (permalink)
Trader Rating: (16)
no sir, nothing, a resonator and a muffler and some pipe thats it lol
Old 05-03-2008, 04:28 PM   #10 (permalink)
boosted
gipper72488's Avatar
Drives: 1990 gsx eclipse
gipper72488 is an unknown quantity at this point
haha there is nothing wrong with owning a sohc. you cant find a tougher motor. and if you go as far as having custom parts made you can be quite fast. but as far as exhaust goes, get 2.5 piping, and if you can go without a cat, do so. if you want a muscle sound go with flowmaster 40series. if you want the import sound, the hks mufflers sound pretty good
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote
