Old 04-24-2008, 07:03 AM   #1 (permalink)
Drives: 91 Stealth
91Stealth89 is an unknown quantity at this point
Default SOHC A/C Removal ?
Hey upon searching the smaller belt size for A/C removal, everything I found seems to apply to the DOHC, are they the same, if not anyone know the part number for the correct belt, thanks
-Ian
1991 Stealth Base SOHC:
2.5” 3SX Dp, Test pipe, full 2.5” catback into an N1 muffler, Ground Control coilovers/KYB GR-2 Struts, Maximal Performance Adj. rear camber arms, Maximal Performance Solid mounts, UP Front and rear Strut tower braces, Seattle VR4 Short Shifter, HHH Palm logger, 3SX Solid Shifter bushings, Addco 1” Front Sway bar, Ebay MAF adapter and AEM cone filter, Exedy Stg 1 clutch, 3SX 8K H.I.D.S, Clutch damper delete, Pwr steering delete, Int delete, 3SX 1G H4 conversion Housings, 3KGT SL wheels.
^ FOR SALE, 3500, BUFFALO NY, PM ME
91Stealth89 is offline   Reply With Quote
Old 04-25-2008, 09:29 AM   #2 (permalink)
Drives: 91 Stealth
Default Re: SOHC A/C Removal ?
Bump...
Old 04-27-2008, 08:19 AM   #3 (permalink)
Drives: 91 Stealth
Bump A/C is gay
Old 04-27-2008, 08:36 AM   #4 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (76)
Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7Stealthee Level 7
On the SOHC the AC is on its own belt.
Old 04-27-2008, 09:57 AM   #5 (permalink)
Drives: 91 Stealth
Am I as retarded as I think Im am, goin to look now
Edit: I failed HARD...go me, thanks stealthee
