Old 03-27-2008, 03:08 PM   #11 (permalink)
Jman649916 is an unknown quantity at this point
Default Sweet...y'all are awesome
Wish me luck tomorrow
Jman649916 is offline   Reply With Quote
Old 03-28-2008, 07:46 AM   #12 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
Default Re: Setting the timing on an NA DOHC
Luck has nothing to do with it!
Work smart, and double check everything as you go.
-SP
One of 789
Old 03-28-2008, 02:07 PM   #13 (permalink)
Average poster
DBLerman's Avatar
Drives: '94 3000GT
DBLerman is an unknown quantity at this point
Work smart, and triple check everything as you go.
-SP
Fixed
DBLerman is offline   Reply With Quote
Old 03-28-2008, 04:16 PM   #14 (permalink)
Worldwide.
BoeJielski's Avatar
Drives: The Bionic Car
Trader Rating: (6)
BoeJielski is an unknown quantity at this point
and once you triple check everything, run it through at least 2 revolutions by hand... if you feel any impacting or tightness, then for the love of god, fucking stop and evaluate the situation. i bent 6 intake valves on the back head because i rushed ;[
also, if you pull the plugs, running it through will be a lot easier. and don't turn the crank backwards or you will more than likely jump time.
we can rebuild it. We have the technology.
myspace.
BoeJielski is offline   Reply With Quote
Old 04-24-2008, 05:45 PM   #15 (permalink)
Computer Wiz
doggie504's Avatar
Drives: 93 SL,90 XJ6 75k mi.
doggie504 is an unknown quantity at this point
Wow this helps me a little, my 93 sl is not running and we think 1) jumped time 2)bad starter 3)bad coils
doggie504 is offline   Reply With Quote
