p/o engine swap - 3000GT/Stealth International Message Center
Old 11-25-2012, 08:20 AM   #1 (permalink)
Drives: 92 sl
humananimal is an unknown quantity at this point
Feedback Score: 4 reviews
Default p/o engine swap
im confused as to what the previous owner (cant contact) did and what sensors and ecu i am realy supposed to have.
the car is a 92 sl. when i bought it i was told the engine was a 95.
the engine has the cas near the fpr and it is adjustable.
if i understand rite this was only on engines up to 92 and to put a 95 engine in the ecu would have to be switched.
was it possible for him to put the 95 engine in and switch things over so that the sensors jive?
does anyone know what ecu would have been in a 92 sl and what one for a 95??
humananimal is offline   Reply With Quote
Old 11-25-2012, 08:59 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1
Feedback Score: 3 reviews
Default Re: p/o engine swap
1st gen has ONE ignition sensor on the rear head. 2nd gen has a sensor on the belt side of the rear head and by the harmonic balancer. The wires on the timing cover are a giveaway there.
Inventive people have figured out ways to install either engine in any year car.
Pull your ECU and post the number and someone who knows these better than I do will tell you exactly which is which, or do a little searching. Its in more than one thread.
-SP
Old 11-25-2012, 12:04 PM   #3 (permalink)
Drives: 92 sl
-SP
thanks.
ya this has just the one sensor but is supposed to be a 95. that why im confused
Old 11-25-2012, 06:07 PM   #4 (permalink)
Paid Member
GTwizard's Avatar
Drives: Mitsubishi
GTwizard Level 1GTwizard Level 1
Feedback Score: 5 reviews
The 1st gen CAS is able to be intalled on 2nd gen heads. That CAS was moved from old motor to new motor.
OTHERWIZE
you would need the 2nd gen harness and ECU. The 2 ECUs are NOT interchangeable as they entirerly bifferent plug configuration.
So stop trying to out guess what was done. Instaead, open a manual and start reading.
Mods
OBX long tube headers, Flow master single 3" in with dual 2.5 outs. VR4 runners with 2 liter plenum, port matched lower intake, stage 3 or better race preped heads with 1 mm oversize Rev valves, Rev race dual springs and Rev keepers, Delta/HKS 272 cams, 3SX adjustable cam gears, 3.0 Cobra Mustang Throttle body, 3.0 LT1 maft and Maftranslater gen II, Alum. Flywheel, Spec stage 5 clutch, VR4 injectors, Wizard wires, Unorthadox under drive. IPS fuel rails w/adj FPR, Fuel loop, Walboro 255 hot wired, Hot wired single fan. Short shifter, Battery relocate. EBC front slotted rotors, EBC Yellow stuff Pads, 3SX SST brake lines, sway bars, springs.
No IAC, NO AC, NO extra weight, VR4 ECU as of NG2011. Still 10 to 1 slugs, Nitto NT05 Comptition Road Course Racing tires. Magan coil overs, 3sx adjustable rear links.
http://www.youtube.com/watch?v=2s0I3tnGGmg[/url]
1st place fastest NA - TXG 2012. 1ST place highest hp NA-240 FWHP TXG-2012. 1st place fastest NA - Drag - TXG 11 98mph, 1st place quickest NA - drags 14.773, 1st place Dyno - TXG11 229 FWHP & 236 tq, 2ND place Auto cross NA C/S- NG2011, 1ST place NA dyno - TX gathering 2010 - 229 FWHP & 199 tq, 1st place Fastest NA - TXG 2010 - 98.3 trap, 1st Place quickest NA - TXG 2010 - 14.680, 2ND place 1/4 at NG10, best NA time NG10 - 14.932- no traction, 2ND place 1/4 at NG09,
2ND place Autocross NG09
GTwizard is offline   Reply With Quote
Old 11-26-2012, 04:49 AM   #5 (permalink)
Drives: 92 sl
man I'm so sick of this open the manual bull shit.
have you seen the pictures in there? you cant even make out what they are trying to show you. i had to look at actual photos from this site just to find the sensors. i have good reading comprehension and still get confused on some of the testing procedures and alot of the info in there is very vague and runs you in circles. also my manual is on my computer which for some reason is even harder to follow.
we aren't all "wizards"
Last edited by humananimal; 11-26-2012 at 04:51 AM. Reason: had to spell check for the anal mofos
Old 11-26-2012, 03:57 PM   #6 (permalink)
Drives: 93 Stealth Stock DD
rymer21280 is an unknown quantity at this point
Feedback Score: 40 reviews
You should have a MD159963 or 9962 A 94\95 fed spec ECU will work in a 92 but if you still have a single cas they should have kept the 92 ECU.
rymer21280 is offline   Reply With Quote
Old 11-26-2012, 07:54 PM   #7 (permalink)
Drives: 92 sl
ccol. so whats the difference between the 9963 and 9962? anything?
Old 11-26-2012, 08:11 PM   #8 (permalink)
9962 is cali spec, and 9963 is federal spec.
Your car will have EGR and more then one o2 if it's cali spec.
Old 11-27-2012, 06:04 AM   #9 (permalink)
Drives: 92 sl
its fed. thanks for the help
