Old 04-21-2008, 09:36 AM   #21 (permalink)
Ultimate seller of things
Drives: 93 dodge stealth es
amiturbo Negative 1
Default Re: Need some help with my N20
Terry what would a good gap be for someone running a 75 shot??
Coming soon, Blue Stealth Extrodinaire, Single turbo ATX
Thanks ChampagneR/T for downpipe,BigTyla for tt atx ecu write up, etc
amiturbo is offline   Reply With Quote
Old 04-21-2008, 09:49 AM   #22 (permalink)
Drives: 3000GT
hawk362 is an unknown quantity at this point
Def. copper don't think twice about the plugs, you said you have plans for 75-150, you are definitely going to need to upgrade to a twin turbo fuel pump. Window switch will be needed as well, glad to hear you invested in the wet kit. Since you do plan on using much bigger shots in the long run, invest in a SAFC and proper tune, with your EGT gauge you'll be set. If you plan on upgrading higher than a 100 shot, definitely save up some money and get a direct port wet system. That amount of nitrous, you really want to make sure you have an even distribution, also I know the 2.5lbs seems small and conservative, but I'd highly reccommend a 10lb bottle, after 1-2 runs with your tiny bottle the pressure must drop pretty low, considering your not even running a bottle warmer either. So to sum it up
1.Copper Spark Plugs, no substitute or easy way out of this, now that you have 75 shot
2.190lph fuel pump- bought mine used on 3si for $40
3.SAFC will be a must for your future plans
4. Bottle Warmer/Bigger Bottle- You wont be getting the right amount of power if your bottle pressure is low ideally you should be at 850-950psi, Nitrous gauge can help monitor this not a expensive investment either knock off brands go for $20-40 on ebay.
5.Window Switch is a must, this will allow for traction, set the nitrous for when you want to engage and cut off, my car I have it set to 3600rpms-6600rpms.
6. Anything over a 100 wet shot, you may need to consider direct port setup, and or forged pistons depending on how your going to go with the shots.
ATX 95 Base 3000GT
Off brand intake, 3sx downpipe, test pipe, custom exhaust, 3sx underdrive pulley, NGK PLUGS, lamborghini doors, 18 inch black rims, limo tints, GTR HIDS, Alpine in dash dvd screen,
ZEX 100 WET NITROUS SHOT
"WOW YOUR CAR IS SO SPARKLY, WHITE, AND DAMN SEXY YOU MIND IF I SNORT IT?"
hawk362 is offline   Reply With Quote
Old 04-21-2008, 10:47 AM   #23 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (177)
Maximal is an unknown quantity at this point
Stock gap will work.
Terry
Maximal is offline   Reply With Quote
Old 04-21-2008, 11:10 AM   #24 (permalink)
amiturbo Negative 1
Thanks.
Old 05-04-2008, 06:03 AM   #25 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
aapstealth is an unknown quantity at this point
Okay I was looking into PLugs for my wet shot. Im going to run a 50shot and maybe go up but not sure. So A stock PLug gap will work. I also have a New stock NA fuel pump will this work. Also I really dont wanna run copper as I think they foul out easily. What about some NOLOGY Spark plugs? They have a silver core and dont say they cant be run with N2O any thoughts? ALSO BUMP for an older thread
aapstealth is offline   Reply With Quote
Old 05-05-2008, 06:48 AM   #26 (permalink)
Supporting Vendor
Maximal's Avatar
You want Copper...platinum or whatever else that is out there does not burn as hot and will not work. They won't last as long as the platinums (I replace them every year) but they cost like $2 a piece so it's not like expense is an issue.
Old 05-05-2008, 01:03 PM   #27 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
Alright sounds good. Im bought a set of NGK Copper and a set of NGK PLatnuims. Im going to do a compression check on the motor before adding any N2O. If the compression is good then coppers and a 50shot for now. If compression is not so good new plugs and wires and holding off on the N20 till my new motor is built.
Also will my NA pump and injectors be okay with a 50shot? I have a new fuel pump maybe a month old.
Old 05-05-2008, 01:08 PM   #28 (permalink)
Supporting Vendor
Maximal's Avatar
If you're just going a 50 shot it should...just keep an eye on your fuel pressure (kit should come with a fuel pressure safety switch). Since it's a wet kit injectors won't matter.
Old 05-07-2008, 10:50 AM   #29 (permalink)
Banned from Classifieds
cbird89's Avatar
Drives: 1993 Dodge Stealth
cbird89 is an unknown quantity at this point
hey aap (this is amiturbo at the moment) if you need someone to take a ride and help you with anything like install wise or whatever just let me know...it took me like 3 1/2 hours to install my venom set up (few wires) It's bad ass right now on stock motor i'm running around a 65 shot...i'm probably gonna install my TT fuel pump this weekend, i plan on turning it up even higher after i get another aem afpr so I can turn the fuel pressure up a lil bit.
cbird89 is offline   Reply With Quote
Old 05-07-2008, 12:33 PM   #30 (permalink)
Supporting Vendor
Maximal's Avatar
You shouldn't need to adjust FP to get more nitrous...it does it by itself on a dry kit and the wet kits are meant to run at basic fuel pressure.
