Old 03-21-2008, 08:14 PM   #1 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
aapstealth is an unknown quantity at this point
Default Need some help with my N20
Well after some thought and Research Ive decided to put the NX 50 DRY shot I have on my car with the GIANT 2.5lb Bottle LOL Anyway I wanna moniter this thing even being so small, So what gauges should I look into too?? I heard wideband or EGT and too be honest IM not fimilar with ethier. Also should I change out my plugs for colder ones and upgrade the fuel pump. From the research I found I dont think I need a fuel pump upgrade and might be able to get away with standard copper plugs, BUT want some advise so chime in and let me know.
aapstealth is offline   Reply With Quote
Old 03-21-2008, 08:25 PM   #2 (permalink)
Member #0711
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (7)
defgh1 is an unknown quantity at this point
Default Re: Need some help with my N20
My advice is to trade your "Dry Shot" for a "Wet Shot"! IMO the risk of leaning your motor out with a Dry Shot is not worth the risk.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 03-22-2008, 10:34 AM   #3 (permalink)
1992 Stealth RT
jbavousett's Avatar
jbavousett Level 1jbavousett Level 1
^^^ Listen to the man. Go wet.
jbavousett is offline   Reply With Quote
Old 03-23-2008, 07:06 AM   #4 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
Bump Anyone else got any ideas?? I already have the dry shot but dont think a 50 shot is that bad in dry N20. I will use it carefully and moniter it. Also is it worth it for me to invest in a wideband? Anyone?
Old 03-23-2008, 07:37 AM   #5 (permalink)
!!Too Much Nitrous!!
Drives: 99 3kgt
Doulos85 is an unknown quantity at this point
Wideband Might be helpful, Terry at Maximal Recommends an EGT for Nitrous.
Just be careful with that Nitrous, Only use it at WOT and a Dryshot should be ok.
Doulos85 is offline   Reply With Quote
Old 03-23-2008, 11:32 AM   #6 (permalink)
gipper72488's Avatar
Drives: dodge stealth
gipper72488 is an unknown quantity at this point
I would go with the EGT if possiible, but a minimum of the wideband. im thinking of putting a 50shot on my stealth. let me know what way you go, and how it works for you
"Shut up, brain, or I will stab you with a Q-Tip!!"
93 white dodge stealth SOHC-craving boost!!!
93 toyota pickup sr5 4wd-workhorse
77 nova project-under the knife
gipper72488 is offline   Reply With Quote
Old 03-23-2008, 03:41 PM   #7 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
Alright not trying to be a smart ass but Im not sure what a EGT is or how it functions can someone explain?
Old 03-23-2008, 03:59 PM   #8 (permalink)
Member #0711
defgh1's Avatar
Trader Rating: (7)
A EGT measures the temperature in the exhaust. A high EGT ~900C+ can indicate a lean cylinder condition and the possible danger of melting components. However, with a N2O "Dry Shot" you can easily lean out a cylinder faster than the EGT gauge can indicate the temperature increase and you will be SOL!
Doug H
Old 03-23-2008, 04:17 PM   #9 (permalink)
Drives: 99 3kgt
Doug H
Terry recommends it because you can get too hot with nitrous without getting out of what we would consider safe on a wideband. I only run a wideband on my nitrous, but I run a wet kit tuned WAY safe (Like Sub 11.0 AFR)
Old 03-23-2008, 05:58 PM   #10 (permalink)
Supporting Vendor
Maximal's Avatar
Drives: '91 Stealth "ES"
Trader Rating: (177)
Maximal is an unknown quantity at this point
EGT should be all you really need. If you want to be really safe look into a wideband too.
A dry system will be fine, especially just with a 50 shot. I was running a 100 dry shot without any issues for a while.
I would suggest getting a bigger bottle though. With a 2.5lb one you're only going to get a 1 full 1/4 mile out of it.
Terry
Maximal is offline   Reply With Quote
