Old 05-06-2008, 06:02 AM   #1 (permalink)
VillasenorStealth's Avatar
Drives: 1994 Stealth R/T
VillasenorStealth Negative 3
Default Need Help With Swap
Look i bought a 91 and 94 stealth r/t. the 91 stealth engine is bad but the (standard)transmission is good. in the 94 stealth the engine is good but the (auto)transmission is bad. so i'm wondering which should i swap what into? the engine to the 91 or the (standard)transmission to the 94? i know its kind of confusing but help would be very appreciated cuz i need at least one working car. I would rather put the 91 standard transmission into the 94 but since the 94 was originally automatic will it work?
Thanks jonathan
VillasenorStealth is offline   Reply With Quote
Old 05-06-2008, 07:43 AM   #2 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (24)
Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4Monster Stealth Level 4
Default Re: Need Help With Swap
I would vote for swapping the 5 speed into the 94 stealth. You get to keep the updated body style and will not have to worry about wiring and any ignition timing abnormalities between a 91 and 94 ecu. The 5 speed swap can be done and you have a parts car so you should be good to go.
9b 13.2 w/ 93 Pump
Originally Posted by Ron Burgundy
Lot Lizards Love Salisbury Steaks
Monster Stealth is offline   Reply With Quote
Old 05-06-2008, 08:35 AM   #3 (permalink)
Thumbs up Re: Need Help With Swap
Thanks. I'll probably do the swap this weekend or next
