Low coolant but no leaks anywhere... - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 03-21-2009, 01:04 AM   #1 (permalink)
GeeTee3k's Avatar
Drives: 1995 3000GT SL
GeeTee3k is an unknown quantity at this point
Feedback Score: 4 reviews
Question Low coolant but no leaks anywhere...
Like the title says, I just filled up my coolant to the full line, 170 miles ago, and already it's low enough where the light is on. I'm not leaking out of the radiator drain plug (which I had been before, but I got all that fixed up) and I also haven't noticed any sluggish acceleration, loss of power, milky oil or even white smoke from my exhaust. I'm really stumped here. I know a decent amount about engines, but I'm certainly not an expert, so if anyone has any advice, I'd really appreciate it. Thanks so much,
Rob
GeeTee3k is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 01:29 AM   #2 (permalink)
Talk about a shortshifter
Hard AttacK's Avatar
Drives: 91rttt, 95 miata
Hard AttacK Level 1Hard AttacK Level 1
Feedback Score: 23 reviews
Default Re: Low coolant but no leaks anywhere...
well how hot does your car get? could it be burning it?
Originally Posted by fastnelson View Post
went over 250 one time
Originally Posted by ADiggidoyoF View Post
I took her to carmax for an appraisal and after a half hour of compliments and friendly small talk they offered me a grand total of $300. I then asked to use the bathroom and proceeded to fill the back part of the their toilets with full rolls of tp.
Hard AttacK is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 09:34 AM   #3 (permalink)
U.S. Marine
gipper72488's Avatar
Drives: A slow dsm
gipper72488 is an unknown quantity at this point
Feedback Score: 0 reviews
get it pressure tested. sounds like it could be the lower intake gaskets
I <3 booost. 90gsx. 3inch turbo back magnaflow exhaust,K&N, shortshifter, stage 2 clutch, mbc at 16psi
gipper72488 is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 10:10 AM   #4 (permalink)
chriskart09's Avatar
Drives: a dream!
chriskart09 is an unknown quantity at this point
Feedback Score: 11 reviews
My car was doing this and the problem was the Turbotimer. I'll explain. Whem I turned off the car, the timer goes on (30seconds), BUT the radiator fans don't work in timer sessions (was a wrong install!), resulting in hot water backing to the plastic bottle (I don't know the name) over filling it. When I return to car and start on gain, the light was on.
I take 2 weeks to find... damm, I hope this help u.
Chris, Brazil
____________________________
"Police did not forgive the traffickers. God forgives. The police only promotes their meeting"
chriskart09 is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 11:06 AM   #5 (permalink)
Light Weight BABY!
3KGT21's Avatar
Drives: 95 3000GT SL
3KGT21 is an unknown quantity at this point
is your coolant overflow filled? there is a sensor in there that would make your coolant light come on.
K&N FIPK/Maximal Single Shot Exhaust/ Stop Tech Slotted Rotors/ Tenzo GT-5 18's/ Nitto NT555's/ Maximal Solid Engine Mounts/ MSD 8.5mm Wires/ NGK Copper's/ Top Line Engineering Ground Wire Kit/ 120k Service =P
3KGT21 is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 06:40 PM   #6 (permalink)
GeeTee3k's Avatar
It actually doesn't get that hot, normal operating temperature I'd say. However, I was driving home the other day going about 80mph when I noticed my oil temp was up around 220 (which it never had been over 200) and the coolant temp was 3 ticks away from the max. Since I installed the oil temp gauge over winter, I never saw it get that high because there was cold air cooling the engine, and the day I was driving home, it was about 70*. I was running 5W30 and thought that maybe it was just getting hot because it was a lighter weight, so I did an oil change to 10W30 since it's getting warmer here in Illinois, and temperature wise, it has been fine.
I was planning on doing that when I did my plugs soon, so we'll see.
Chris, Brazil
My car is an N/A.
Yes, I filled it to the max line and about 170 miles later, the light is coming on.
BUT: I noticed today that my coolant light comes on when I start the car, and once it's at normal operating temperature, the light seems to go off but comes on every now and then when I stop quick (probably because the sensor is in the back of the tank, and the coolant moves forward when I stop). BUT the coolant is nonetheless low, so it's gotta be going somewhere...I'm stumped :\
Old 03-21-2009, 06:52 PM   #7 (permalink)
943kgtsc's Avatar
Drives: Supercharged 3k!!
943kgtsc is an unknown quantity at this point
Feedback Score: 1 reviews
drive it around till it hot (pressure the hoses)then park and turn off ignition. watch for any hissing sound (or leak) in engine bay that how i found out my heater hose was leaking slowly
943kgtsc is offline   Reply With Quote Quick reply to this message
Old 03-21-2009, 09:52 PM   #8 (permalink)
GeeTee3k's Avatar
I appreciate all the input guys but I'm NOT leaking anywhere...if there was a leak, I wouldn't have to ask what to do, I'd replace whatever it was that was leaking.
Old 03-21-2009, 10:42 PM   #9 (permalink)
Lohnes68's Avatar
Drives: 94' fwd TT
Lohnes68 is an unknown quantity at this point
head gasket blown? check your oil fill cap. if its wet, its blown, if not, then u have a leak somewheres, u just cant see it cuz its running from hose to hose to hose etc....just a suggestion
Lohnes68 is offline   Reply With Quote Quick reply to this message
Old 03-22-2009, 01:37 PM   #10 (permalink)
Big SERBIAN
gavric's Avatar
Drives: 1994 3000GT
gavric is an unknown quantity at this point
Feedback Score: 6 reviews
I had a problem for longest time with same thing. it turned out to be leaking by water pump when under the pressure but becasue engine got hot it burned it off right away. Put antifreeze in and get it hot, then open the hood and try to sniff and smell. if its leaking and burning off it will smell like "sweet". Also i have seen leaking problems and same burning off so you cant see it by freeze plugs. http://www.econofix.com/3plug.jpg
gavric is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
