Old 04-17-2008, 11:17 AM   #1 (permalink)
myviper is an unknown quantity at this point
Default knocking sound from motor!!AH!!
alright so I went and change out the plugs and wires with new ones, no problems at all...no cross threadings or anything falling in accidentally into the manifold or the cylinders. Changed them with OEM replacement plugs and wires, and about two seconds after I started teh motor there is now a knocking sound coming from the right end front bank cylinder. Did a compression test and came up 60 or so checked the other ones and they were all arond 160 I think. WTF?! happened? all I did was change plugs and wires. When I took out the plug on that cylinder it has oil on it, but all the other ones are clean no oil. Could something of just decided to fuck off on me right then??? I need help asap as where my car is a daily driver and I have no other vehicle
Its a 93 Stealth R/T Automatic with 205kms, and i just changed the oil last thursday with mobil synthetic 5w30.
myviper is offline   Reply With Quote
Old 04-17-2008, 11:26 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Default Re: knocking sound from motor!!AH!!
Yikes man. Drain your oil, look for either shards of metal or swirls of coolant. The metal would be a spun bearing (copper) and the coolant would mean a blown headgasket.
Feel your timing belt for tension.
You sure it isn't lifter tick?
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 04-17-2008, 01:52 PM   #3 (permalink)
oh ya man this is an obvious difference in noise
Old 04-17-2008, 02:02 PM   #4 (permalink)
gipper72488's Avatar
Drives: dodge stealth
gipper72488 Level 1gipper72488 Level 1
drain your oil and look for the metal shavings. how bad is the knock? is it slight knock, or does it sound like someone is knockn from the inside with a hammer? a vid would help
I <3 booost
93 sohc-sold
90 gsx-purchased 6/5/08
3 inch turbo back exhaust
valve job, ported head
MBC set at 14psi
gipper72488 is offline   Reply With Quote
