Idler/tensioner help - 3000GT/Stealth International Message Center
Old 11-23-2012, 08:28 PM   #1 (permalink)
tylovejoy is an unknown quantity at this point
Feedback Score: 0 reviews
Default Idler/tensioner help
My uncle looked under my hood and said that the bearing in the idler seems to be going out so it was making some noise. He said I should replace both tension pulleys and the idler (attached pic) because they are usually replaced at the same time.. Since he's not too tech savvy and I'm not too auto savvy, can someone please help me find the OEM parts on the web to order?
It'd be much appreciated!
(Also, sorry if this isn't in the correct forum!)
Idler/tensioner help-untitled.png
tylovejoy is offline   Reply With Quote
Old 11-24-2012, 10:58 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1
Feedback Score: 3 reviews
Default Re: Idler/tensioner help
I'm amused that the upper left corner is identified as "generator". (which havent been used in cars since the early 60's!!)
Aftermarket parts are OK for this. Despite the theory for all three to fail at about the same time, I have not found that to be true. You can replace one or all three. Just realize that since its an old car any part can fail at any time for no real reason.
-SP
Old 11-28-2012, 05:34 PM   #3 (permalink)
Okay so would this part work? It says it's for a VR4 but does it make a difference? I have a 97 SL
STM: OEM MITSUBISHI 3000GT VR4 91-99 | 6G72 | IDLER PULLEY | MD319022
Old 11-28-2012, 07:36 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Thats the timing belt idler.
-SP
Old 11-28-2012, 11:32 PM   #5 (permalink)
Paid Member
GTwizard's Avatar
Drives: Mitsubishi
GTwizard Level 1GTwizard Level 1
Feedback Score: 5 reviews
Speedy. not feeling well. Bring him up todate about full 60Ks. Hiow many miles on car and all that crap. His uncle is no help to him.
Mods
OBX long tube headers, Flow master single 3" in with dual 2.5 outs. VR4 runners with 2 liter plenum, port matched lower intake, stage 3 or better race preped heads with 1 mm oversize Rev valves, Rev race dual springs and Rev keepers, Delta/HKS 272 cams, 3SX adjustable cam gears, 3.0 Cobra Mustang Throttle body, 3.0 LT1 maft and Maftranslater gen II, Alum. Flywheel, Spec stage 5 clutch, VR4 injectors, Wizard wires, Unorthadox under drive. IPS fuel rails w/adj FPR, Fuel loop, Walboro 255 hot wired, Hot wired single fan. Short shifter, Battery relocate. EBC front slotted rotors, EBC Yellow stuff Pads, 3SX SST brake lines, sway bars, springs.
No IAC, NO AC, NO extra weight, VR4 ECU as of NG2011. Still 10 to 1 slugs, Nitto NT05 Comptition Road Course Racing tires. Magan coil overs, 3sx adjustable rear links.
http://www.youtube.com/watch?v=2s0I3tnGGmg[/url]
1st place fastest NA - TXG 2012. 1ST place highest hp NA-240 FWHP TXG-2012. 1st place fastest NA - Drag - TXG 11 98mph, 1st place quickest NA - drags 14.773, 1st place Dyno - TXG11 229 FWHP & 236 tq, 2ND place Auto cross NA C/S- NG2011, 1ST place NA dyno - TX gathering 2010 - 229 FWHP & 199 tq, 1st place Fastest NA - TXG 2010 - 98.3 trap, 1st Place quickest NA - TXG 2010 - 14.680, 2ND place 1/4 at NG10, best NA time NG10 - 14.932- no traction, 2ND place 1/4 at NG09,
2ND place Autocross NG09
GTwizard is offline   Reply With Quote
Old 11-29-2012, 03:46 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Sorry you're not feeling well my friend. Get well soon.
60k is all about the timing belt and related components.
As far as I can tell you are just concerned about the pulleys for the accessory belts.
If you cant get them at your parts store, a favored dealer that gives us a discount is Cherry Hill.
-SP
