Old 04-15-2008, 09:19 PM   #1 (permalink)
one day at a time
dudewutup's Avatar
Drives: 95 base
dudewutup is an unknown quantity at this point
Exclamation i hate little problems
i just got inshurance on my car and am able to rive it now the thing is my idle is crazy it idles high and after it is warm the car goes nuts and revs up and down quiclky what may be the cause?
dudewutup is online now   Reply With Quote
Old 04-15-2008, 11:00 PM   #2 (permalink)
one day at a time
dudewutup's Avatar
Drives: 95 base
Default Re: i hate little problems
i really do hate it bump for help
Old 04-16-2008, 04:32 AM   #3 (permalink)
HugeJay's Avatar
Drives: 92 R/T
HugeJay is an unknown quantity at this point
check your idel up control valve, sounds like its acting flakey
HugeJay is offline   Reply With Quote
Old 04-16-2008, 04:38 AM   #4 (permalink)
SOHC Abuser
Konfyoused's Avatar
Drives: 1991 Stealth base
Konfyoused is an unknown quantity at this point
could also be the MAS
I really need to put something here, don't I??
Konfyoused is offline   Reply With Quote
Old 04-16-2008, 04:53 AM   #5 (permalink)
M. Dawg
sask's92redstealthTT's Avatar
Drives: '92 Stealth R/T TT
sask's92redstealthTT is an unknown quantity at this point
Air in the cooling system? Unlikely, but just thought I'd throw it out there as this happened to one of my cars recently.
sask's92redstealthTT is offline   Reply With Quote
Old 04-16-2008, 07:30 AM   #6 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
Look around carefully for disconnected or leaky vacuum lines. ALso if you had your TB off its easy to put the gasket in backwards and cause a vacuum leak there too.
-SP
One of 789
Old 04-16-2008, 12:10 PM   #7 (permalink)
one day at a time
dudewutup's Avatar
Drives: 95 base
were is the vacume controll valve and do you have a diagram of the vacume line routing?
Old 04-16-2008, 09:49 PM   #8 (permalink)
ooeygooey is an unknown quantity at this point
TPS sensor.....
ooeygooey is offline   Reply With Quote
Old 04-16-2008, 10:47 PM   #9 (permalink)
Worldwide.
BoeJielski's Avatar
Drives: The Bionic Car
Trader Rating: (6)
BoeJielski is an unknown quantity at this point
i'm bankin on a vacuum leak.. check all your hoses and see if they're all solid.. and also check for brittle, deteriorating hoses.. and those lil engine gnomes who steal souls.
you do any work on it lately?
we can rebuild it. We have the technology.
myspace.
BoeJielski is offline   Reply With Quote
