How to: tighten the timing belt? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 07-18-2004, 11:17 PM   #1 (permalink)
girls go fast too
siragan's Avatar
siragan is an unknown quantity at this point
Feedback Score: 0 reviews
Default How to: tighten the timing belt?
I don't have one of those fancy manuals-on-CD yet, and I was wondering what the proper procedure was to tighten the timing belt on the 3.0L DOHC engine. I already did a search for back posts, but couldn't find what I needed. My timing belt is so slack, it smacks the block and makes a ton of noise.
thanks in advance.
siragan is offline   Reply With Quote Quick reply to this message
Old 07-18-2004, 11:48 PM   #2 (permalink)
Big SERBIAN
gavric's Avatar
Drives: 1994 3000GT
gavric is an unknown quantity at this point
Feedback Score: 6 reviews
Default Re: How to: tighten the timing belt?
No way to make belt tighter without replacing parts. I was looking over for my 120K service instructions and someone mentioned that if your belt is loose you should replace the belt and while you are there do all stuff required for 60K or 120K service.
gavric is offline   Reply With Quote Quick reply to this message
Old 07-19-2004, 08:43 AM   #3 (permalink)
girls go fast too
siragan's Avatar
Heh. Looks like I'm at the 232K service
Alright. I finally found a post that correlates to what I need:
http://www.3si.org/forum/showthread....g+belt+tension
It turns out that you CAN set the tension how you want it, but you need a special tool from mitsubishi. And yes, I know I *should* replace the parts, but I'm strapped for cash. I'm going to hell, I know I know.
Here are some more questions:
1. Do you need to pull the engine to replace the timing belt and pulleys?
2. How much is the timing belt tensioner tool from mitsubishi?
Old 07-19-2004, 12:57 PM   #4 (permalink)
LUvikes29's Avatar
LUvikes29 is an unknown quantity at this point
Feedback Score: 5 reviews
Timing belt is a ROYAL pain in the arse. Just did it on my VR-4. It's probably worse on that car than an NA because you have to pull off a bunch of the turbo piping etc. In hindsight, I almost wouldn't recommend doing it yourself unless you've got a lift and air tools. It took forever, and was a huge headache.
1991 VR-4 Blue FOR SALE:
84,000 on clock 17K on turbos, tranny, motor, aftermarket clutch
Brand new paint job w/Bomex skirts
New Timing belt/water pump
3" downpipe & full Borla Exhaust w/high perf. cat. &/or testpipe
K&N intake, NGK Plugs, Accel wires, battery relocated to trunk
Corbeau TRS seats, reverse indiglos and aluminum "VR-4" pedals.
Alpine stereo, pioneer speakers
Asking $13,000. Taking offers. Sell by end of summer
LUvikes29 is offline   Reply With Quote Quick reply to this message
Old 07-20-2004, 10:35 AM   #5 (permalink)
girls go fast too
siragan's Avatar
Do you have to pull the engine to replace the belt and pulleys?
Old 07-20-2004, 05:49 PM   #6 (permalink)
Largest Member
chrisstealthes's Avatar
Drives: 91' Stealth ES
chrisstealthes is an unknown quantity at this point
If you have to ask these questions you probably shouldnt be trying to do all of this and you probably dont have all of the tools required to do it. Sorry but it sounds like you dont know a lot about fixing cars and you wouldnt want to mess this up since it would mean the end of your engine.
And yes you would have to pull the engine.
http://www.3sxperformance.com/tools.asp the pulley tensioner can be bought from 3sx for $20
3SX Downpipe, 3SX Crank Pulley, DN Performance N/A Intake Pipe, Stillen Air Intake Kit, Magnecor Wires, Custom Exhaust, Intrax Springs, 3K rear bumper, R/T sail pannels and much more to come.
Chacun Son Gout
chrisstealthes is offline   Reply With Quote Quick reply to this message
Old 07-20-2004, 10:42 PM   #7 (permalink)
girls go fast too
siragan's Avatar
No offense, but I think that this is exactly the wrong attitude to have when working on cars. The only reason why I'm asking questions is because I want to learn what I need to know to get the job done. I've been working on cars for 3 years as a "home mechanic" and I've saved hundreds and hundreds of dollars by doing so. What I'm saying is that I don't give up eaisly. I'm very stubborn and extremely driven to learn and get the job done. However, I appreciate your concern and I do realize that we must know our limits. I know mine, I just choose to ignore them.
I spoke with the local dealer, and I have arranged to photocopy sections of the factory manual so I can use the factory torque specifications when I install the new timing items. I always make sure that the work gets done properly. Always. And if that means buying specialized tools for the job, so be it.
After a substantial amount of digging, I finally found a website that describes how to do it. And you don't have to pull the engine. Only the driver's side motor mount.
http://www.vr4stealth.com/60k-tune.htm
This one picture answered all of my questions, and I'm posting it up to help out those in the future who are in the same position as I am:
You can see that the hydraulic tensioner exerts a force on a rotating bracket that holds the timing belt tensioner. Since the force applied by the hydraulic tensioner is SET by the factory (at x newtons), the goal is to use that 2-pronged tool to essentially rotate the tensioner pulley (which rotates about a non-centerline axis), which thus pushes on the hydraulic tensioner. In order to determine if the tension is correct, you are supposed to be able to remove a pin from the hydraulic tensioner which becomes "unsnagged" when the factory force of x newtons is applied.
This is all explained in instruction step 26 on the webpage.
I hope this helps somebody out in the future.
Old 07-21-2004, 08:35 AM   #8 (permalink)
driven
-bluej's Avatar
Drives: 92 ES
-bluej is an unknown quantity at this point
Feedback Score: 2 reviews
the most important part in doing your 60k is getting the tension right on the timing belt. i messed up when i did it this spring and now i'm getting my heads rebuilt with new intake valves becuase the belt slipped and they hit the pistons. i was lucky though, could've been worse.
in other words, THE TENSION IS VERY IMPORTANT!!!!!!!11!!1!
but, if you trust your mechanical abilities you should do ok. a few things to keep in mind:
-two sites to review: the one you put above and www.us3s.com. both have sections on the 60k service.
-buy a damn manual. you'll wonder afterwards why you hadn't bought it sooner. seriously, for $15 you can get it on cd.
-buy the damn special tensionor tool. some people manage without but it'll save you headaches later.
-the cam sprocket holders rock. for a half hours worth of your time before doing the service and a trip to the hardware store they will be a huge help. (i'm talking about the wooden wedges with the bolt through it to keep the cam sprockets in place at TDC.)
lastly, QUADRUPLEDUPLEDOUBLEDUPLE CHECK EVERYTHING! no no. no questions there, just do it
good luck!
-bluej is offline   Reply With Quote Quick reply to this message
Old 07-21-2004, 06:14 PM   #9 (permalink)
Go get bent
LUSTFUL's Avatar
Drives: Just a NA
LUSTFUL is an unknown quantity at this point
you do not have to pull the motor.. i did my complete 60k in 8 hours. the tensioner tool can be bougt from 3sx i beleive. there are several 60k guides around and if you take your time and follow the instructions you will be fine. tension is basically governed by the tensioner. are you referring to it being slack with the car off?? if so it is supposed to have some freeplay in that condition. why i forget but it is
'93 Dodge Stealth ES: BPU and a bit more maybe
Hey bois duz dis ebay chip work make mah whip teh fasterest?
LUSTFUL is offline   Reply With Quote Quick reply to this message
Old 07-21-2004, 09:14 PM   #10 (permalink)
girls go fast too
siragan's Avatar
I've gone over the whole 60K tuneup procedure, and I understand all parts of it thoroughly, except for one:
- what is the "correct" procedure for removing the crank pulley center bolt?
On the 60K tune I read, the guy loosens it by bracing the 1/2" socket wrench against the ground or something, then cranking the engine over. Which is pretty funny how ghetto that is. Anyway, that's all fine and dandy for getting the bolt off, but then how does he put it back on?
Also, when you put it on, how to you keep the crankshaft rigid (make it so the force of you screwing the bolt in doesn't turn the engine over)? I was thinking about putting the engine in gear, but then the torque of the crankshaft would turn the driver's side wheel (the one that you have to take off to gain access to the crankshaft bolt anyways).
I'm saying that it is slack with the car running. It's so slack, it hits the waterpump pulley very hard. Hard enough to make a very loud and rhythmic noise which eventually goes away at 2000rpm when the belt is going so quickly that it can't vibrate anymore. The belt is so loose, I can move the teeth of the belt foward or backward a notch on the cam gears with my hands without much difficulty. It's amazingly dangerous. I bought it off a guy in maryland who was convinced it was the lifters, and he had been driving it like this for several thousand miles. I can't believe it hadn't slipped off. It scares the hell out of me to even start the engine up.
Anyway, the reason why the timing belt is slack in some parts and tight in others when the engine is off is because the camshafts have "at rest" positions. When they're inbetween positions (when they're pushing down valves), they exert a torque on the cam pulleys, therefore artifically tensioning the belt.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
