How do I check manual trans fluid? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 05-01-2003, 05:51 PM   #1 (permalink)
Super Asurada SA-01
Prime12's Avatar
Drives: EVO X
Prime12 Level 1Prime12 Level 1Prime12 Level 1
Feedback Score: 5 reviews
Default How do I check manual trans fluid?
ok ok another n00b stick driver question..
first off I have 97 3000GT 5-spd base.
when I had an automatic trans sentra it had ATX trans fluid dipstick at the engine bay, so I could just check the level as I was checking engine oil. But I couldn't find one in my 3000gt. It's my first manual transmission vehicle, so I don't know if there is supposed to be one at all.
my mechanic checked it while doing 60k service and said it was ok, but my shifter is being notchy these days and I thought I would need to check it.
so...how do I check mtx transmission oil level? and is changing transmission oil easy to do myself?
I'm not the most mechanically inclined person.. I installed supermac cold air box and filter myself, thats about it
Sang Yi
#32, SJR / NNJR / Philly
2016 Philadelphia Region Championship - 1st place, B-Street
Prime12 is offline   Reply With Quote Quick reply to this message
Old 05-01-2003, 05:59 PM   #2 (permalink)
14.1 @ 100mph N/A
WICKEDDREW's Avatar
WICKEDDREW is an unknown quantity at this point
Feedback Score: -4 reviews
Default
Take the 17mm fill plug loose. It's on the front of the tranny facing the bumper. If fluid pours out or if you can feel fluid when you stick your finger in the hole(that sounds nasty), your level is fine.
WICKEDDREW is offline   Reply With Quote Quick reply to this message
Old 05-01-2003, 08:13 PM   #3 (permalink)
Super Asurada SA-01
Prime12's Avatar
Drives: EVO X
Default
thanks! if the level is fine, can I just assume my tranny oil is ok? do I need to check anything else?
Old 05-02-2003, 03:39 PM   #4 (permalink)
14.1 @ 100mph N/A
WICKEDDREW's Avatar
Default
It nevers hurts to replace it. You'll need a 22 or 24mm socket (can't remember, but you should be able to find it on 3si), a 1/2" drive ratchet to get some good leverage on the drain plug, a drain pan, 3 quarts (1 and just shy of a half) of gear oil, and a funnel with a long flexible attachment... NAPA sells a cool plastic one that works great.
I use Royal Purple, but any brand should do as long as it's 75w-90.
Old 05-02-2003, 04:09 PM   #5 (permalink)
Drives: SL
JimmyJames is an unknown quantity at this point
Feedback Score: 0 reviews
Default
24mm short socket
=j=
My car: 91 3000GT SL
My band: http://NumbOnes.com
JimmyJames is offline   Reply With Quote Quick reply to this message
Old 05-02-2003, 04:29 PM   #6 (permalink)
14.1 @ 100mph N/A
WICKEDDREW's Avatar
Default
...AKA "the greasy one" in my toolbox.
Old 05-20-2012, 02:47 PM   #7 (permalink)
Always Learning
mikeyVR4's Avatar
Drives: 2013 WRX Prem 4D WRB
mikeyVR4 is an unknown quantity at this point
Feedback Score: 8 reviews
Default Re: How do I check manual trans fluid?
Can someone post up a picture or a small diagram of where the plug is on the 6spd.? I am not sure where to add the fluid and check the levels.
Rep. for help
mikeyVR4 is offline   Reply With Quote Quick reply to this message
Old 05-21-2012, 09:31 PM   #8 (permalink)
Wheee! 2 wheels is fun!
speedy25's Avatar
Drives: Various Japanese
speedy25 Level 1speedy25 Level 1speedy25 Level 1
Feedback Score: 7 reviews
But NOT any brand that says GL5.
-SP
speedy25 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
