Old 04-11-2008, 06:43 AM   #21 (permalink)
jdshookup's Avatar
Drives: 92 Dodge Stealth R/T
jdshookup is an unknown quantity at this point
Default Re: High idle on cold start up, hesitation, etc....
Yeah it's on the front of the throttle body (towards the front of the car) ... do you have the CAS thing or not?
I think I have the CAS, I thought all 1st gens with DOHC have them. If that is the case, I should have it. I'll take a look later today to confirm.
A little update about my car:
My buddy said it could be the clutch slipping. I thought be was crazy. But I remembered if I don't let my car warm up (because it starts off at 2000rpm when cold) and let it get to normal rpm, then when I take off it will always grind going into second gear.
Does that indicated clutch problems? It never grinds gears when the car is warmed up.
jdshookup is offline   Reply With Quote
Old 04-11-2008, 08:42 AM   #22 (permalink)
jdshookup's Avatar
Update...
I do have the CAS, I just looked under the hood. And what am I looking for to be wrong with the TPS? Because, it appears to look normal.
Old 04-11-2008, 08:56 AM   #23 (permalink)
Wingless 3000GT Club
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (54)
lawdogg Level 7lawdogg Level 7lawdogg Level 7lawdogg Level 7lawdogg Level 7lawdogg Level 7lawdogg Level 7
I thought there was a write-up on Stealth316 about TPS adjustment ... shoot, I can't find it.
It's a shot in the dark.
2002 WJ -- 1994 VR-4 -- 1993 ZJ --Canon Rebel XTi
Old 04-11-2008, 11:26 AM   #24 (permalink)
jdshookup's Avatar
Hopefully one of us can find the write up! If you find it, please share the link! I have to get going to work. It sucks, I just keep thinking about getting my car fixed, and I'm working 60hrs a week!
Old 04-11-2008, 11:32 AM   #25 (permalink)
lawdogg's Avatar
Trader Rating: (54)
Found it in the wiki!
TPS Throttle Position Sensor Adjustment - 3SI Wiki
Old 04-13-2008, 07:54 AM   #26 (permalink)
jdshookup's Avatar
Update...
I talked to a couple people they think it might be my clutch slipping. Is that possible????????
Old 04-13-2008, 10:35 AM   #27 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (74)
Stealthee Level 5Stealthee Level 5Stealthee Level 5Stealthee Level 5Stealthee Level 5Stealthee Level 5
Not even remotely possible.
Old 04-14-2008, 10:47 AM   #28 (permalink)
jdshookup's Avatar
hmmmmm.....
Old 05-08-2008, 04:27 AM   #29 (permalink)
jdshookup's Avatar
Okay... update for anyone who still might be interested in what is going on...
Took my car to a local shop to have them take a look at it for free. They say that I have a vaccum leak and the fix would be a new gasket for my upper intake plenium. Hopefully when I get out of work today it'll be nice so I can swap the gasket out and see if it's a fix! Wish me luck!
Old 05-09-2008, 09:31 AM   #30 (permalink)
jdshookup's Avatar
I swapped the gaskets... help a little bit, but there is still hesitation. I'm thinking maybe the fuel filter or pump. Might try that.
