Old 06-17-2008, 10:03 AM   #1 (permalink)
Drives: 91 3000GT SL
danaocity is an unknown quantity at this point
Default Is the HHData logger can remove the check engine light?
Can HH data logger can remove the check engine light? Can retrieve a code.?What is the procedure? How to remove the check engine light?
danaocity is offline   Reply With Quote
Old 06-17-2008, 10:07 AM   #2 (permalink)
3000GTVR41994's Avatar
Drives: 08 Eclipse RIP VR-4
Trader Rating: (11)
3000GTVR41994 is an unknown quantity at this point
Default Re: Is the HHData logger can remove the check engine light?
Yes it can. Basically just connect up the usb plug or w/e u use to your laptop and turn the key on(don't start the car) Then connect the software to the ecu. Once connected there is a button on the top right toolbar area and it figures i forget the name of it now... The icon looks like a notepad almost. CLick it and in there it will give your a readout of the errors reported and a button to erase. Hope this helps
Rob
Mod List: K&N cone, DNP Y-Pipe, TurboXS RFL BOV, Custom down pipe and full 3" exhaust, Apexi AVC-R Boost Controller @ 15PSI, Apexi SAFC-II, 450CC DSM Blacktop Injectors, MSD 8.5MM wires w/ NGK copper plugs, Spec Stage 2+ clutch, RPS Billet Flywheel, Custom stereo system, Seibon Carbon Fiber Hood, Enkei 18"x8.5" RZ-5 wheels w/ Falken Ziex 912, AEM WB 02, HHH Hybrid Logger w/ wideband integrated, VAC reduction, EGR delete w/ blockoffs, Mcculloch 10,000K HID low beams
3000GTVR41994 is online now   Reply With Quote
