Old 04-26-2008, 10:53 AM   #1 (permalink)
Phillipistuning's Avatar
Phillipistuning is an unknown quantity at this point
Mitsubishi HELP! whats a good throttle body
I want to install a new GOOD throttle body in my car, and I was just wondering who makes the best.
Phillipistuning is offline   Reply With Quote
Old 04-26-2008, 06:01 PM   #2 (permalink)
Average poster
DBLerman's Avatar
Drives: '94 3000GT
DBLerman is an unknown quantity at this point
Default Re: HELP! whats a good throttle body
Stock is fine. You will see very little, if any, gains from a different TB.
DBLerman is offline   Reply With Quote
Old 04-26-2008, 06:56 PM   #3 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (22)
Monster Stealth Level 1Monster Stealth Level 1
If you are dead set on it. Best bang for the buck imo is the q45 throttle body.
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box
Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255
Suspension/Wheels/Brakes
OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's
Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms
Exterior/Interior/Dress-up
Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket
6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album
Monster Stealth is offline   Reply With Quote
Old 04-27-2008, 11:40 AM   #4 (permalink)
thanks
