Old 05-04-2008, 08:50 PM   #1 (permalink)
3KGTVT's Avatar
Drives: 1995 3000GT SL
3KGTVT is an unknown quantity at this point
Default Help with coolant light!
Hey guys. I have been having a problem with my coolant light, wondering if anyone else has had the same problem. Every morning when i head to work, the coolant light comes on when i apply the brakes at the first stop sign i come to. Once i release the brakes it shuts off. After the car is warmed up to half way up the gauge, it wont do it again. Any ideas?
3KGTVT is offline   Reply With Quote
Old 05-04-2008, 09:00 PM   #2 (permalink)
hyperblu is an unknown quantity at this point
Default Re: Help with coolant light!
My guess would be you're low on coolant. Braking will slush around the coolant and set off the light and when you take off and stay at a steady speed it will go away. Just add 1/2 gallon of mix to the coolant resevoir... Correct me if i'm wrong, but the coolant level will rise as the engine is warmed up and will not set off the sensor..
hyperblu is offline   Reply With Quote
Old 05-04-2008, 09:10 PM   #4 (permalink)
3KGTVT's Avatar
Originally Posted by WhiskeyIsQuick View Post
yea...thats kind of a simple problem...those lights are there to tell you whats wrong...coolant light...check your coolant...DOH!
So technically theres only a problem for around 7 seconds. If it constantly stayed on, thats a problem. DOH
Old 05-04-2008, 09:17 PM   #5 (permalink)
Mitsubishi Re: Help with coolant light!
I had the same problem in my cavalier. the light would come on when taking curves or hard braking in autox (haha laugh at me for autox'ing in a cavy) You wont be laughing after you see if go. Hahn Stage II Turbo FOOL! hah. But seriously, Im sure a VR4 would roast my puny 2.2 200whp ecotec =(
