Ground wire kit Installation - 3000GT/Stealth International Message Center
Old 03-01-2008, 01:58 PM   #1 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT 1992 VR4
aapstealth is an unknown quantity at this point
Feedback Score: 23 reviews
Default Ground wire kit Installation
Hey got a ground wire kit from Big Tyla but it didnt have instructions searched and found out of date links can anyone provide me with a intsllation guide PLEASE
aapstealth is offline   Reply With Quote
Old 03-01-2008, 02:04 PM   #2 (permalink)
ATL
MK_94_3000GT's Avatar
Drives: 22 and counting
MK_94_3000GT Level 1MK_94_3000GT Level 1
Feedback Score: 145 reviews
Default Re: Ground wire kit Installation
Topline Engineering Ground Wire Kit Instructions
*Before installing each wire, be sure to clean off the install area. For chassis grounds, be sure to sand down the paint for optimum grounding.
*Your kit should have the following:
Two 8” wires (one for chassis to terminal and one for alternator to chassis)
Three 10” wires (one for throttle body to terminal, one for head to head, and one for chassis to intake plenum)
One 18” wire (for rear head to terminal)
One 20” wire (for transmission to terminal, manual transmission will have 27” wire)
Step 1: disconnect the negative terminal wires (if you want more room to work with, disconnect the positive terminals as well and remove the battery from the vehicle). Then disconnect the intake elbow from the throttle body and the MAS.
Step 2: remove the smaller negative terminal from the chassis (nearest the battery) and replace it with one of the 8” wires.
Step 3: remove the negative terminal from the transmission and replace it with the 20” wire. (NOTE: cars with a manual transmission use a 27” wire). Some models may vary and this mounting point may not work due to the size of the bolt. Alternatively, any place on the transmission is a good ground.
Step 4: remove the top –left 12mm bolt from the throttle body and install one of the 10” wires to the bolt. Reinstall the bolt to the throttle body (if this causes interference for turbo cars, mount in bottom-left bolt).
Step 5: remove the bolt that connects to the rear head as shown below, and place the bolt through the end of the 18” wire and the other 10” wire (WARNING: some 91-92 cars have a CAS here, so this point should not be used unless you are comfortable with adjusting timing. Alternatively, you may want to use the next nearest bolt). Reinstall the bolt.
Step 6: remove the bolt that connects to the front head (near the coolant cap) and install the other end of the 10” wire.
Step 7: remove the forward driver’s side alternator mount nut and install one end of the remaining 8” wire. Remove the nearest radiator mount bracket bolt and install the other end of the 8” wire. Reinstall the nut and bolt.
Step 8: Replace the wire that connects from the chassis to the back of the intake plenum with a 10” wire.
Step 9: Connect the remaining 4 loose ends to the negative battery terminal and start her up! Enjoy your new ground wires!
These are the instructions but with no pictures, this should help out some.
MK_94_3000GT is online now   Reply With Quote
Old 03-04-2008, 06:44 PM   #3 (permalink)
I'm a Troll
trbotalon is an unknown quantity at this point
Feedback Score: 0 reviews
aapstealth where's my money
trbotalon is offline   Reply With Quote
Old 04-01-2008, 08:14 PM   #4 (permalink)
The Student
LeigerReign's Avatar
Drives: 92' VR$
LeigerReign is an unknown quantity at this point
Feedback Score: 2 reviews
Thanks alot for these instructions. I had all the 8guage wire i needed laying around and really wanted to make one of these. Thanks again, and ill post back to let you know if there was a noticeable difference.
LeigerReign is offline   Reply With Quote
Old 04-09-2008, 11:10 PM   #5 (permalink)
The Student
Drives: 92' VR$
Noticeable throttle response difference, as well as start up times. Worth the $10
Old 01-14-2009, 03:03 PM   #6 (permalink)
chitownJvr4's Avatar
Drives: 93 3000GT VR4
chitownJvr4 Negative 1
Where can i get this Wire at. would a hardware store carry it along with the fittings to crimp onto the wire
chitownJvr4 is offline   Reply With Quote
Old 01-14-2009, 03:34 PM   #7 (permalink)
Moments From Boost
Crackhedbob341's Avatar
Drives: 96 3000GT 5 Spd
Crackhedbob341 is an unknown quantity at this point
All you need is ring terminals that fit the correct gauge wire, and optional solder.
Crackhedbob341 is offline   Reply With Quote
Old 05-31-2009, 02:24 AM   #8 (permalink)
cricketman1986's Avatar
Drives: 3000GT SL
cricketman1986 is an unknown quantity at this point
Where's BigTyla. I need instructions with pics. Please help!
cricketman1986 is offline   Reply With Quote
Old 03-31-2010, 11:23 PM   #9 (permalink)
street_approved is an unknown quantity at this point
i think i have this in a kit i just bought. Im trying to figure out how to install mines as well. Where does this ring terminal go ?
street_approved is offline   Reply With Quote
Old 04-01-2010, 08:56 AM   #10 (permalink)
2fnloud's Avatar
Drives: 94 Stealth R/T TT
2fnloud is an unknown quantity at this point
Feedback Score: 4 reviews
When you say "terminal" you are referring to the negative battery terminal correct?
MODS
Performance: Hennessey Stage 5 Tuning | AEM EMS series 2 | AEM 4 channel CDI | HKS "mushroom" twin intake | HKS EVC I | TD04 13G's | Centerforce dual friction clutch | Ninja Performances 70A fuel pump hot wire | 3SX Poly motor mounts
Exhaust: HKS D-2 cat-back | Stillen D/P | 3SX Rear pre-cat delete
Suspension: Working E.C.S. | TEC Performance front strut bar | TEC Performance rear strut bar
Brakes: 3SX SS lines | SCE W.I.D.E. floating rotor brake kit | SCE Caliper stiffening bolts | Powdered calipers & rotor hats(front) | Panther XP-8(front) / AX-6(rear) brake pads | Titanium shims(front) | JDM front brake ducts
Electrical: BigTyla Ground kit in 1/0GA | 2 BatCap 2000's
Looks: 96' Replica banana spoiler | Window Tint | 99 blinkers | 3KGT2NV Allen head bolt kit | Seattlevr4 roller bearing STS | Morgan front splitter | Yellow & black carbon fiber dash kit
Security: Viper 5902 | Remote start | Four 110Db piezo sirens (gives great headache) | Smart start | Glass sensor | Tilt sensor | Hatch release
Things in red are yet to be installed
____________
Originally Posted by jbeard1 View Post
I would be scared to screw something up, and my car would end up pulling a "Toyota" xD
2fnloud is offline   Reply With Quote
