Originally Posted by kevin.cook64
Would this be what I am looking for as far as the crank angle sensor? Also if there was no check engine light should I still be worried about the CAS? And would I still be getting any kind of spark out of any of the coil packs if it was bad or would they all be dead? Since one coil pack was giving spark.
It is pretty rare for a CAS to fail. It is more likely the crank angle sensor is not adjusted properly or has come loose. Especially if you did the timing belt recently. Check it before replacing it. Here is a photo of its location. And yes, that is a the crank angle sensor in your photo.
This seems to be my real issue with this design is that codes do not always show up in diagnostics from what I have read on this forum. Makes it a real pain. I would much rather gamble, if I was sure the crank sensor was secured, on the coil pack and PTU. Always good to have a spare set anyway even if it proves to be the wrong bet. Plus, it is a much easier fix.
