#2 (permalink) |
Possibly your IAC(idle air controller) Located on the throttle body. Pop it off and clean it out. Should fix your issue. Below is a link for how to do it.
Stealth 316 - ISC Servo Motro Rob
Mod List: K&N cone, DNP Y-Pipe, TurboXS RFL BOV, Custom down pipe and full 3" exhaust, Apexi AVC-R Boost Controller @ 15PSI, Apexi SAFC-II, 450CC DSM Blacktop Injectors, MSD 8.5MM wires w/ NGK copper plugs, Spec Stage 2+ clutch, RPS Billet Flywheel, Custom stereo system, Seibon Carbon Fiber Hood, Enkei 18"x8.5" RZ-5 wheels w/ Falken Ziex 912, AEM WB 02, HHH Hybrid Logger w/ wideband integrated, VAC reduction, EGR delete w/ blockoffs, Mcculloch 10,000K HID low beams |
#3 (permalink) |
same thing happened to mine found out it was my mas air flow sensor dont know how it happened but it did i dont even remember touching the MAFs but what ever it is all better now
it didnt do it every time just 1 of 20 and the trouble light never came on even has a local shop scan it and do some testin g and he couldnt even see any problems |
