Engine differences Auto vs manual tranny - 3000GT/Stealth International Message Center
Old 11-12-2012, 03:08 PM   #1 (permalink)
justjim's Avatar
Drives: Holden Monaro
justjim is an unknown quantity at this point
Feedback Score: 1 reviews
Default Engine differences Auto vs manual tranny
We spun a bearing in our Chump Car Mitusubishi 3000GT which had a 91 engine with manual tranny in it. We were able to get a JDM replacement and got the "newer" engine in the car. The only issue was the wiring harness that came with the engine didn't match exactly. The engine is from a car that had an automatic, so we are assuming the harness issue was because of that. We had an extra harness laying around so we just swithced harnesses and the engine seems to run good although we have road tested it yet.
So here's the question, Are there any internal differences in the auto tranny engines versus the manual tranny engines that we need to know about such as camshafts? We are using the ECU out of a 94 that matches the cam angle sensors for this engine. Just wondering if we need to switch camshafts or if we are good to go as is.
There are only 3 sports, Bullfighting, Motor Racing and Mountain climbing. All the rest are games.
Earnest Hemingway
justjim is offline   Reply With Quote
Old 11-13-2012, 05:02 PM   #2 (permalink)
Paid Member
GTwizard's Avatar
Drives: Mitsubishi
GTwizard Level 1GTwizard Level 1
Feedback Score: 5 reviews
Default Re: Engine differences Auto vs manual tranny
No differance what so ever. It's all the same. Other the the issue of 1st gen or 2nd gen for the CAS. Just install the CAS from the first gen head to the 2nd gen and run 1st gen harness. Bottom line, motors ,cams and such all the same.
Mods
OBX long tube headers, Flow master single 3" in with dual 2.5 outs. VR4 runners with 2 liter plenum, port matched lower intake, stage 3 or better race preped heads with 1 mm oversize Rev valves, Rev race dual springs and Rev keepers, Delta/HKS 272 cams, 3SX adjustable cam gears, 3.0 Cobra Mustang Throttle body, 3.0 LT1 maft and Maftranslater gen II, Alum. Flywheel, Spec stage 5 clutch, VR4 injectors, Wizard wires, Unorthadox under drive. IPS fuel rails w/adj FPR, Fuel loop, Walboro 255 hot wired, Hot wired single fan. Short shifter, Battery relocate. EBC front slotted rotors, EBC Yellow stuff Pads, 3SX SST brake lines, sway bars, springs.
No IAC, NO AC, NO extra weight, VR4 ECU as of NG2011. Still 10 to 1 slugs, Nitto NT05 Comptition Road Course Racing tires. Magan coil overs, 3sx adjustable rear links.
http://www.youtube.com/watch?v=2s0I3tnGGmg[/url]
1st place fastest NA - TXG 2012. 1ST place highest hp NA-240 FWHP TXG-2012. 1st place fastest NA - Drag - TXG 11 98mph, 1st place quickest NA - drags 14.773, 1st place Dyno - TXG11 229 FWHP & 236 tq, 2ND place Auto cross NA C/S- NG2011, 1ST place NA dyno - TX gathering 2010 - 229 FWHP & 199 tq, 1st place Fastest NA - TXG 2010 - 98.3 trap, 1st Place quickest NA - TXG 2010 - 14.680, 2ND place 1/4 at NG10, best NA time NG10 - 14.932- no traction, 2ND place 1/4 at NG09,
2ND place Autocross NG09
GTwizard is offline   Reply With Quote
Old 11-14-2012, 04:38 PM   #3 (permalink)
justjim's Avatar
Thanks, just wanted to be sure, it's being dynoed tomorrow.
