Old 06-02-2008, 09:51 PM   #1 (permalink)
Trader Rating: (11)
94 White RT is an unknown quantity at this point
Default 96 R/T Check Engine Code 505 Idles up and down.
I have a 96 Stealth R/T non turbo 5 speed Cali-spec, that I just bought and the idle goes up and down from about 1200-1600. The car is throwing a check engine code of P0505. I tried swaping out the TPS and no luck. I think the ecu on the car may have been changed by the prior owner. Is there anthing else I can do to fix this or do I need to take it to a mechanic. Any help would be great. Thanks.
94 white rt.
94 White RT is offline   Reply With Quote
Old 06-03-2008, 08:20 AM   #2 (permalink)
NO Barack HUSSEIN Osama!!
blusilvr's Avatar
Drives: PiMpMobile
Trader Rating: (67)
blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7
Default Re: 96 R/T Check Engine Code 505 Idles up and down.
where u find it, what color is it? post pics
Lamborghini Marketing VP describing Countach- "on the down side, you can't take packages, there are only two seats so no kids, only a beautiful woman. The white one, she is like a virgin. The red one is like a mature woman, the black one like an intriguing woman."
blusilvr is offline   Reply With Quote
Old 06-04-2008, 12:30 AM   #3 (permalink)
ooeygooey is an unknown quantity at this point
When you swapped out the TPS did you set it right or just bolt it back on the intake?
ooeygooey is offline   Reply With Quote
Old 06-04-2008, 03:08 AM   #4 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: A Mitsu made turd...
Trader Rating: (97)
SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7SOHC3000GT Level 7
IAC malfunction...
'93 Green 3000GT
Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms / UP rear strut bar / Seattle short shifter / TurboBob 8,800 rpm ECU
PM me about 3S service in the Kansas City area.
SOHC3000GT is offline   Reply With Quote
Old 06-08-2008, 08:25 PM   #5 (permalink)
Trader Rating: (11)
When I put it in I set it. Also if it is a IAC malfunction how can I prove this and what do I need to replace to fix it?
Old 06-08-2008, 08:26 PM   #6 (permalink)
Trader Rating: (11)
I found it locally, and it is Red with Tan leather.
QUOTE=blusilvr;4883119]where u find it, what color is it? post pics[/quote]
Old 06-08-2008, 09:18 PM   #7 (permalink)
blusilvr's Avatar
Drives: PiMpMobile
Trader Rating: (67)
sweet , I have never seen a red/tan 96 rt na.
Old 06-11-2008, 07:12 PM   #8 (permalink)
Trader Rating: (11)
Anyone?
Old 06-11-2008, 07:23 PM   #9 (permalink)
12212012
ZombieMaster's Avatar
Drives: 92RT/TT, 02WRX
ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7ZombieMaster Level 7
OBD1 and OBD2 Codes -
'92 Stealth RT/TT
'02 WRX Wagon
94 SL - parting out
ZombieMaster is offline   Reply With Quote
Old 06-15-2008, 07:00 PM   #10 (permalink)
Trader Rating: (11)
I wound think that a Idle Control system malfunction would be the IAC valve, which I swapped out with another car, and it still did not fix it. What other checks can I do to narrow down the problem.
