Old 04-13-2008, 03:10 PM   #21 (permalink)
Drives: 94 Dodge Stealth R/T
StealthPanda StealthPanda StealthPanda StealthPanda StealthPanda
Default Re: 3.5l Pajero Engine Swap
I was researching this subject when i ran across this... Quite a bit of interesting information here. Things like MIVEC, GDI, performance versions... Its all there., this line of engines is very interesting.
Browser Warning
StealthPanda is offline   Reply With Quote
Old 04-14-2008, 02:33 PM   #22 (permalink)
shty's Avatar
Drives: 92 RT NA
Trader Rating: (9)
shty is an unknown quantity at this point
are u guys using the same ecu does the 3.5L have VICS stills?
'92 RT
PArts for Sale 2008 still available- http://www.3si.org/forum/showthread.php?t=369574
shty is offline   Reply With Quote
Old 04-15-2008, 09:01 AM   #23 (permalink)
Mit3sx is an unknown quantity at this point
We used the same ECU from the 3k on the 3.5L, no problems at all, runs great.
Mit3sx is offline   Reply With Quote
Old 04-15-2008, 09:14 AM   #25 (permalink)
HUGE!!! I have some mods on it already I can go up to 75 on second gear a little bit before redlining. It has definitely way more torque than the 3.0
Another member who did the swap said
lol. congrats man. i just did the swap myself. i'm sure you will have a grin from ear to ear when you realize the difference. i just took mine to the track and broke a cv shaft from the torque. it will run a low 14 once i get new tires, and a cv shaft. i'm at 14.5 now. :^
are you planning on doing this swap?
Old 04-15-2008, 09:54 AM   #28 (permalink)
My old engine was already burning a lot of oil and I did no want to rebilt it so I did some research on the 3.5L Pajero, the engine alone was $ 1399 plus $340 for shipping and $300 for install. So around $2040. I also considered doing a TT swap but the engine alone was at least $1800 for a Gen 1 plus cost of shipping, install and all the accessories like intercooler with pipes, oil cooler, ECU and other lines and hoses. I decided on the 3.5L because I did not had a lot of money to go TT and I needed my car soon for school and work.
If you are planning on doing something similar, go for it, either way you won't regret it.
Old 04-15-2008, 07:18 PM   #29 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
zkruly87 is an unknown quantity at this point
and later on if you find yourself with some more cash. put the TT swap on the 6G74.
zkruly87 is offline   Reply With Quote
Old 04-21-2008, 03:00 PM   #30 (permalink)
\m/
