Old 03-01-2008, 12:27 PM   #11 (permalink)
autopsycho's Avatar
autopsycho Level 1autopsycho Level 1
Default Re: 3.5l Pajero Engine Swap
Originally Posted by zkruly87 View Post
I'm actually on my way over to finish up the swap on my 94 3000gt. so far everything is direct replacement. we're dropping it in and firing it up today. i'll repost with the results.
P.S. so far no mod has been necessary.
Great work... would love to know the results.
autopsycho is offline   Reply With Quote
Old 03-02-2008, 12:56 AM   #12 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
zkruly87 is an unknown quantity at this point
ran out of time on the swap today. the 93 talon tsi i'm driving dropped a cylinder. turns out the #1 injector plug came unclipped. whoops. so do to troubleshooting we didn't get as far on the 3000 as a complete startup. but the engine is completely in and bolted up. all we are missinig is the wire haness the coolant lines and the halfshafts. the only possible problem we have found is that this engine is without a doubt taller. about 3/4" more from cams to crank. we're taking bets on whether or not the hood will fit. hmmm. excuse for new hood maybe...
zkruly87 is offline   Reply With Quote
Old 03-07-2008, 02:00 AM   #13 (permalink)
max3 is an unknown quantity at this point
if u get a stock vr4 motor and bore the cylinders out will it be better than the 3.5 liter pajero?
max3 is offline   Reply With Quote
Old 03-07-2008, 05:44 AM   #14 (permalink)
STL3S
whitedragon's Avatar
Drives: 98SL 3.5L
whitedragon is an unknown quantity at this point
The stock hood will fit the 3.5 unless you did something really weird. Mine fits fine.
whitedragon is offline   Reply With Quote
Old 03-07-2008, 12:15 PM   #15 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
not really no. the most you can really bore a 6g72 block to safely is 3.1L. a 6g74 can be bored out to 3.7, 3.8, possibly even 4.0L and still be safe. and a 3.5L would spool the turbos faster. there is no replacement for displacement. holds true whether you are a ricer or a muscle head.
Old 03-16-2008, 08:10 PM   #16 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
drove the 3500 home today. runs like a charm. and the motor is so quiet you could sleep next to it. not the exhaust though. lol
Old 03-19-2008, 06:15 AM   #18 (permalink)
STL3S
Drives: 98SL 3.5L
9b's do not have enough flow to really get goin on the 3.5. TD05's are the way to go. PM Xwire for more info.
Old 03-20-2008, 08:22 AM   #19 (permalink)
3g3000gt's Avatar
Drives: 1994 3000gt
3g3000gt is an unknown quantity at this point
It would be like doing a standard tt conversion with less room to work, and some cutting and grinding in some points.
Tony
3g3000gt is offline   Reply With Quote
