Old 02-26-2008, 01:17 PM   #1 (permalink)
Mit3sx is an unknown quantity at this point
Default 3.5l Pajero Engine Swap
has anyone done the 3.5L PAJERO ENGINE SWAP? How are the power gains?
Mit3sx is offline   Reply With Quote
Old 02-26-2008, 01:47 PM   #2 (permalink)
My Stealth is Confused...
Stealth_E's Avatar
Drives: w/o a front plate OH
Stealth_E Level 1Stealth_E Level 1
Default Re: 3.5l Pajero Engine Swap
Yes, the 3.5 engine has been swapped - using some 3.0 parts and some 3.5. Fabrication is necessary to make it all work. Use the search feature, there is already a lot of info available.
Stealth_E is offline   Reply With Quote
Old 02-26-2008, 01:53 PM   #3 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (12)
ras463us Level 1ras463us Level 1
FWD or AWD?
The FWD is nearly a drop in.
The AWD requires modifying the oil pan, and the thermostat housing/waterneck.
Depending on which block you get, there are some mount bosses that also might need to be machined for either application. The Pajero engine that I got has the correct mounting boss heights.
Check out www.wrenchmonkey.com, this is John Monnin's (sp) install/converion site. It is for a TT application but is an excellent resource.
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 02-26-2008, 02:23 PM   #4 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P is an unknown quantity at this point
Was it the 3.5 or 3.7 that are making 300BHP with upgrades. so can help you out a lot.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway.
L_P is offline   Reply With Quote
Old 02-27-2008, 10:27 AM   #5 (permalink)
Thanks for all your replies, my engine needs to be rebuilt and I was considering the swap as an option, I also was considering rebuilding my engine with ross 11:1 compression ratio, performance cam gears and head valves, which would be better?
Old 02-27-2008, 10:49 AM   #6 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 1Barefoot Level 1
3.5 liter.. more room for improvment.
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Twin TD05H EvoIII 16G's - Garrett FMIC - PTE 680cc - IPO Propane Injection - Maftpro - SouthBend DXD-F - PST CFDS - Northbend OS - Kaaz LSD - Cianci Victory Hood - Cianci Novara Bumper - Forged Internals 1mm over - and MUCH more..
Barefoot is online now   Reply With Quote
Old 02-27-2008, 12:59 PM   #7 (permalink)
TeamZer0's Avatar
Drives: 93 3000GT
TeamZer0 is an unknown quantity at this point
NA 3.5L discussion
check this thread out
TeamZer0 is offline   Reply With Quote
Old 02-27-2008, 08:08 PM   #8 (permalink)
TeamZer0's Avatar
Drives: 93 3000GT
http://www.jdmenginedepot.com/jdm_en...T/Montero_6G74
Old 02-28-2008, 07:21 AM   #9 (permalink)
Thanks you all, this has helped out a lot, I'll do this conversion hopefully during spring break and let you all know the results
Old 03-01-2008, 10:14 AM   #10 (permalink)
fL8 mE
zkruly87's Avatar
Drives: '94 3500GT
zkruly87 is an unknown quantity at this point
Talking Re: 3.5l Pajero Engine Swap
I'm actually on my way over to finish up the swap on my 94 3000gt. so far everything is direct replacement. we're dropping it in and firing it up today. i'll repost with the results.
P.S. so far no mod has been necessary.
zkruly87 is offline   Reply With Quote
