Old 08-31-2009, 02:23 PM   #21 (permalink)
Shooter_24's Avatar
Drives: 1995 Stealth R/T
Shooter_24 is an unknown quantity at this point
Default Re: wth is that ticking!
looking up prices to repair my bearing, yesterday we tried the Rislone Engine Treatment just to eliminate possibilities of my problem. im still assured its a bearing or connecting rod(my friends dad's a mechanic but knows more about domestic, thats his guess also), but any estimates on how much this repair would take on our cars for a 3.5?
Shooter_24 is offline   Reply With Quote
Old 08-31-2009, 04:38 PM   #22 (permalink)
Shooter_24's Avatar
ok im just throwing this out there before we order parts, is it possible to use 3.0 heads for the 3.5? stupid question i think. just curious
Old 09-08-2009, 09:01 PM   #23 (permalink)
Shooter_24's Avatar
bumpp... please
Old 09-10-2009, 02:26 AM   #24 (permalink)
DarkPira7e's Avatar
DarkPira7e is an unknown quantity at this point
The problem is that our cars use hydrolic lifters; meaning when they sit for a long time, the oil can drain out of them and they tick a lot; which is what you're hearing. Try running some of the lucas oil treatment with your next oil change, it may help. I also don't know about the 3.0 heads fitting on the 3.5, I would guess no, but I'm sure someone who has the expereince here will be able to tell you! the 3.5 is from the Montero
DarkPira7e is offline   Reply With Quote
Old 09-10-2009, 07:31 PM   #25 (permalink)
Shooter_24's Avatar
ok thanks
Old 10-04-2009, 05:18 PM   #26 (permalink)
Shooter_24's Avatar
started it up today, 10/4/09, this is what it sounds like now.
Old 10-04-2009, 11:12 PM   #27 (permalink)
3000GTO is an unknown quantity at this point
sounds like lifters. very common.
3000GTO is offline   Reply With Quote
Old 10-04-2009, 11:21 PM   #28 (permalink)
Shooter_24's Avatar
thanks 3000GTO, im hoping its lifters but i need more proof. me and my dad are worried that if its a bearing, it could b causing more sh*t to fall apart.
Old 10-04-2009, 11:43 PM   #29 (permalink)
Forum user
Mits3kGT's Avatar
Drives: '91 VR4
Mits3kGT is an unknown quantity at this point
try this..start at idle and rev it to 2k rpm and hold it for a few seconds. Let it drop back to idle then rev to 4k rpm and hold it for a few seconds. Once it returns to idle, blip the throttle to about 5-6k rpm and let it return to idle. Do that last step a few times and see if your tick goes away. I do that every now and then and my tick goes away for a few days. Coincidence? Idk lol
1991 3000GT VRFOUR
http://www.facebook.com/bhodgin
WTB: Krank Vent System, One (1) 18x8.5" 5Zigen FN01RC
Mits3kGT is offline   Reply With Quote
Old 10-05-2009, 05:22 AM   #30 (permalink)
Engine Extraordinaire
Mean Green's Avatar
Drives: 93' VR4
Mean Green is an unknown quantity at this point
lol...that sounds horrible. Sorry but if my car made those noises, I wouldn't even dare start it until I had gone over everything with a fine tooth comb. Sounds like a lifter has completely collapsed or you have spun a rob bearing, its hard to tell.
Edit: Check the oil and see if you see any metal flakes, it will look like metallic paint.
2001 Green Mitsubishi Eclipse - ASA Mesh Wheels wrapped in BFG's
1993 Panama Green VR4 - Fresh Paint - TE37's wrapped in Nitto NT555 - Fresh Build - Fresh Transmission - Stage 4 Clutch - Brass Shift Bushings - KYB GR2 - Tein S-Techs - Maximal Mounts - Maximal Rear Camber adjusters - Custom Autometer Gauges in dash - Ball Bearing Short Shifter - Greddy Prof B Spec 2 - HKS VPC - DSM Side Mounts - Everything in engine bay is Powder Coated or Ceramic Coated - Kenwood Headunit - Dual Infinity Baselinks - Optima red top - Dejon Y pipe w/ Blitz BOV - Heat Wrapped Intercooler piping - HKS turbo timer - Hot Wired Fuel Pump - Walbro 255 - now just waiting on some terdbo's...heh
My parts forsale thread
My Car Before and After
I absolutely HATE price gougers
Quote from my other half: "Some days you have patients and some day's I don't even see how you can do anything at all because your being sooo inpatient."
Mean Green is offline   Reply With Quote
