lifter tick only gets louder if your oil level drops. And if your oil level does drop, you have to worry about spun bearings. a spun bearing can sound alot like lifter tick in its early stages. Hope it is just the lifters in your case. Change the oil, and make sure it is filled all the way up to the full indicator and then let it warm up before checking again. If still getting ticking noises, you'll have to determine if the ticking is lifter generated, exhaust generated, or lower end generated. When it sounds like a a hammer on metal, it isn't the lifters anymore dorothy.... it is the path to hell.
LW
since most of crew is at NG right now, the left overs will have to help you till they get back.
in my 2nd gen stealth a did the 3.5L conversion form JDM, but the engine i got doesnt have the same oil sensor as my car does, so on the gauge, it says 0... i recently did an oil change like, 3 days ago.
this is my problem. its a 3.5L engine from JDM. i really need answers, my brother hasnt been home for awhile and he usually helps with my car. is this a lifter a tick or something else?? i tried to locate from where i think its from coming from.
car wont be even started till we get info on my problem, thanks
this is a result of just 3 revs after buying an engine from a guy that was rebuilt
"this is a result of just 3 revs after buying an engine from a guy that was rebuilt" wat do u mean? is that bad for my car? we rebuilt the entire engine also
well no i bought an engine for 1000 and it was sitting for 2 years and now it broke make sure its all tighntend to torque spec or damn close 2 it
the 3.5 l is from a mirage i belive get that book and mix it with the stealth chrysler book but i bet its the same plus the twin turbos. But im going to try to figure it out tom might even be the oil what filter was used? Also my vr4 had a compression at 10:1 and it felt like i didnt have much power. It felt sluggish and w a dr650 and stock turbo set up it should fly. Any way check your heads first
im young so i do still live with my family, my dad thinks it could be the valves so were checking those today, he says he has lifter tick in his dodge ram sport pickup and mine is alot louder so he thinks its something worse.
Hey guys. I think I have the lifter tick problem as well. I am pretty certain because I just changed my oil and the ticking went away for 1 day and then came back. I am thinking of getting new lifters or getting a new oil pump to help eliminate the noise. Any suggestions on which one I should get...or any other tips for that matter? I am trying to learn as much as I can to get my car running smoothly, but don't want to wast money on random stuff that won't help my car. Let's face it...the ticking noise has got to go!
