Old 02-16-2008, 06:57 PM   #1 (permalink)
King3000gt's Avatar
Drives: 94' 3000gt vr-4
Trader Rating: (7)
King3000gt is an unknown quantity at this point
Default WoT Problem
Hello everyone, I own a 1994 vr4. I need some help!
Will someone please tell me why your car loses power in wide open throttle?
It seems like there is no power past first gear, car just kinda hesitates! I've replaced plugs and fuel pump, checked timing marks everything is lined up.
i need some help please
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs
Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket
Need to purchase- A datalogger! leaning towards halo... got a hybrid!
King3000gt is offline   Reply With Quote
Old 02-17-2008, 06:42 AM   #2 (permalink)
HVY HITR
Erick's Avatar
Drives: 94.99 STEALTH TT
Erick Level 4Erick Level 4Erick Level 4Erick Level 4Erick Level 4
Default Re: WoT Problem
first thing is to pressure test.
Rob Beck sells the tester.
94.99 2nd Gen TT - DR650s & then sum - Daily Driver
Erick is offline   Reply With Quote
Old 02-20-2008, 04:50 PM   #3 (permalink)
King3000gt's Avatar
Trader Rating: (7)
ive got a tester... no boost leaks, compression test read good all cylinders about 130.... anyone know what i should gap my plugs too? might be spark plug blowout! but not sure? whats everyone been gapin theres to with stock boost? my car is probably running rich as well since i tore all the egr crap out! what should i narrow my hesitation cause too or check next ?
Old 02-20-2008, 04:58 PM   #4 (permalink)
BAWC: VP Sarcasm
CursedFish's Avatar
Drives: '93 VR-4
Trader Rating: (6)
CursedFish is an unknown quantity at this point
I'm assuming you're still running on stock turbos - you really won't get a pull all the way to redline.
130ish is a little low - what were the variances between the individual cylinders? actual numbers?
Are you having hesitation? Or is it just slow to accelerate? Anything out of the ordinary on the logs?
- '93 VR-4: RobBeck 13Ts, Emanage, etc
CursedFish is offline   Reply With Quote
Old 02-20-2008, 09:41 PM   #5 (permalink)
King3000gt's Avatar
Trader Rating: (7)
yeah im running stock turbos, all the cylinders read about 145 except cylinders 3 and 5 read about 130... im going to retest them again just to see a change. its wierd b/c first gear is pretty strong but that could be the awd.. but every gear past that just feels slow to accelerate... but just recently when i changed the plugs there is a hesitation in 2ng gear makes a couple poping sounds! im guessing spark blow out....thats why im going to gap the plugs down somemore...
and i dont have a logger... where can i get one? they expensive?
Old 02-21-2008, 09:19 AM   #6 (permalink)
King3000gt's Avatar
Trader Rating: (7)
bump............
Old 02-22-2008, 11:33 AM   #7 (permalink)
King3000gt's Avatar
Trader Rating: (7)
bump... why would car hesitate first couple of pulls and then after its warmed up good, stop popping in high rpm? cant seem to find cause of hesitation, feels like no boost!
Old 04-18-2008, 10:16 PM   #8 (permalink)
King3000gt's Avatar
Trader Rating: (7)
Anyone know why when i put a hotwire kit on my stock fuel pump made the car feel 100x faster? Before i was having problems accelerating and would pop under hit throttle... Well i gapped plugs down to stop the popping, but the car was still accellerating slow. Once i put that hotwire kit on the car runs great!
Before hotwire- 14.3@95mph
After hotwire- 13.3@105mph
Old 04-18-2008, 10:24 PM   #9 (permalink)
Livin' the dream
chargerx3's Avatar
Drives: 92 dodge stealth TT
chargerx3 level 6chargerx3 level 6chargerx3 level 6chargerx3 level 6chargerx3 level 6chargerx3 level 6
good to see the hotwire work. i think i will try it. mine only bested a 14.6 at the track. also try setting your plugs to .034 or somewhere close to that. the stock setup should be .044 gap which is also good, but if you run it really hard at that gap setting then they will start to blow out...foul, and just cause you pain. let us know how it goes
1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)...
1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT (Z) 1996 NISSAN 300ZX TT
Originally Posted by jtvr4 View Post
You are such a dimwit. How does it feel to be an adult with the grammar, and reading skills of an eight year old? Do you even care that your stupid?
chargerx3 is online now   Reply With Quote
Old 04-19-2008, 12:04 AM   #10 (permalink)
King3000gt's Avatar
Trader Rating: (7)
i belevie i gapped my plugs at .32 runs good though other than the transmission wear of 2nd gear
