Old 06-17-2008, 08:16 PM   #1 (permalink)
Drives: 91 vr4
Sammyvr4 Negative 1
Default Will a motor from a non turbo work in a turbo car?
My motor is messed up in my 91 vr4 and I need a new one and was just wondering if a motor from a non turbo car would work in it?
Sammyvr4 is offline   Reply With Quote
Old 06-17-2008, 09:12 PM   #2 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (51)
Forest Gump Level 1Forest Gump Level 1Forest Gump Level 1
Default Re: Will a motor from a non turbo work in a turbo car?
that depends on your definition of "work".
Yes, it will run if you swap the accessories and turbos/manifolds over.
The compression is 10:1 vs the 8:1 of the turbo motor and this will require a tuning and running less boost than the 8:1 motor can.
Power:13Ts, 550s, SAFC, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G front brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO
Forest Gump is offline   Reply With Quote
Old 06-17-2008, 09:14 PM   #3 (permalink)
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
Trader Rating: (7)
lDoomZdaYl is an unknown quantity at this point
Well said.
lDoomZdaYl is offline   Reply With Quote
Old 06-18-2008, 03:39 AM   #4 (permalink)
Drives: 91 vr4
Sammyvr4 Negative 1
So better off to go ahead and get a turbo motor?
Old 06-18-2008, 09:57 AM   #5 (permalink)
Paid Member
Patryn's Avatar
Drives: 3000gt VR4
Trader Rating: (29)
Patryn is an unknown quantity at this point
Yes, or else you will be limited to about 7psi. Compression is higher on the NA engine, so your detonation threshold is lower. However, some of the guys around here do the TT conversion onto their NA engines. Might want to check with them if you have already bought an NA engine.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
Patryn is offline   Reply With Quote
Old 06-18-2008, 10:47 AM   #6 (permalink)
shadow334485's Avatar
Drives: 91 VR4
Trader Rating: (13)
shadow334485 Level 1shadow334485 Level 1
What is thrashed about the VR4 engine? Might be cheaper to replace pistons, bearings and machine work than to attempt to make a N/A engine work
Originally Posted by EVILTWIN View Post
he banned me for nameing myself Reacharound. all i did was enter every thread and ask how he was able to give reacharounds thru all those roll cage bars, while steering and shifting.
shadow334485 is offline   Reply With Quote
Old 06-18-2008, 11:39 AM   #7 (permalink)
lDoomZdaYl's Avatar
Drives: Her Crazy
Trader Rating: (7)
you can do 10 psi or maybe a bit higher but theres always meth injection.
Old 06-18-2008, 12:26 PM   #8 (permalink)
QSpectre's Avatar
Drives: 92 VR-4
QSpectre is an unknown quantity at this point
Isn't the turbo engine forged and the N/A one not forged?
1992 Fiji Blue VR-4
Works now!
QSpectre is offline   Reply With Quote
Old 06-18-2008, 01:16 PM   #9 (permalink)
Drunk as a lord
Trader Rating: (51)
no, year for year forged parts were the same.
Old 06-18-2008, 01:30 PM   #10 (permalink)
Drives: 91 vr4
Sammyvr4 Negative 1
Someone didn't put the thrust bearings in correctly or something in correctly and the peices rubbed some ridges in the block. I'm going to try to get something machined but it doesn't look promising. Does anyone know where I can get just a block for my 91 Vr4?
