Old 03-13-2004, 10:23 PM   #1 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (245)
RobBeck is an unknown quantity at this point
Default Whos running water/alcohol injection with good results>>>
I have become very interested in running water/alcohol mix thru my motor after some reading yesterday. I am very interested in running higher boost on pump... and this seems like the best way.
Is running this type of setup just as well as running higher octance fuel.... or is it better to just run high octane and call it a day?
Who makes the best setup.. cleanest... and little excess shit hanging around... I would like to use windshield wiper resevoir too....
Does anyone inject before the turbo... basically right into the center of the the compressor wheel so you dont have to fight with boost as you try to run it?
Any setups out there either mechanical or electrical that can inject at preselected boost levels?
Any advice or pics appreciated...
Rob
RobBeck is offline   Reply With Quote
Old 03-13-2004, 10:27 PM   #2 (permalink)
none
Robi's Avatar
Drives: 96 vr4
Trader Rating: (10)
Robi is an unknown quantity at this point
Default Re: Whos running water/alcohol injection with good results>>>
Extremely interested in this thread. Seing how I want to build a kit as well.
http://www.turbomirage.com/water.html
thats one site I will be using as a referance.
http://www.florida3s.com
http://www.wildergfx.com<--Vinyl decal creator/designer/cutter/maker/thingamajinkster
Robi is offline   Reply With Quote
Old 03-13-2004, 10:46 PM   #3 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Trevor runs a high volume of Alky with great results.
91VR4-3.0L-Stock heads and Cams-811AWHP 747AWTQ Daily Driver 10.57@141mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 and NG10 Title Sponsor
3SX Performance
3SX Performance Service Email
Carolina 3S Forum
Old 03-14-2004, 02:31 AM   #4 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Using that link and the little paint brush diagram... I manipulated one of my own. As you can see, I am injecting water before the turbo... in a vacuum environment... so having a very powerful pump may not be an issue... and perhaps the standard washer fluid pump can still be utilized? Since the fuel pump is already hotwired.... I could use the OEM fuel pump relay as a source to power the pump... since I only need it for a signal for the hotwire relay at the fuel pump. Other than that... hardly anything else would be required.
I guess more importantly, do you think this would work?
Rob
Old 03-14-2004, 07:57 AM   #5 (permalink)
Rob
Cooling pre turbo will have MUCH less effect than after. The turbo will just heat that right back up. You will get a better cooling effect post turbo.
Old 03-14-2004, 08:27 AM   #6 (permalink)
none
Robi's Avatar
Drives: 96 vr4
Trader Rating: (10)
My thoughts exactly. WOuldnt a kit like this be installed just like a N2O kit? Right before the throttle body for best results?
Old 03-14-2004, 08:43 AM   #7 (permalink)
not a newbie
Drives: 1992 VR4
deterhop is an unknown quantity at this point
I remember reading an article somewhere stating that injecting before the turbo has to be so very precise because there is hardly any room for error in the injection pattern. The turbo compressor wheel weighs very little and the fins are usually pretty thin. Injecting before can actuall run a risk of damaging these fins if a a spray becomes uneaven because of too heavy a mixture like when dialing in a setup.......this is what i read not sure how it actually applies
1992 VR4
Current Mods: generic air filter, fuel pump rewire, ngk copper plugs, proboost mbc, short-shifter, gutted precats, ESP downpipe, 3" test pipe, 1st gen DSM BOV, 60k service
deterhop is offline   Reply With Quote
Old 03-14-2004, 09:52 AM   #8 (permalink)
Forum Moderator
HilbillyHomeboy's Avatar
Drives: Tin Indian
Trader Rating: (39)
HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2
Talk to Mikes95RT. He runs it and is very knowledgable. I don't know much about it as I plan to run propane(Thanks IPO!)
-Jeremy
HilbillyHomeboy is offline   Reply With Quote
Old 03-14-2004, 11:52 AM   #9 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
I guess you know of persons who have done it his way with undesirable results... or have done yourself?
I spoke of some reading I did the other day in my first post... and it was www.eng-tips.com. I tell ya... these guys have to be some of the smartest bastards I have ever seen. Refer to the posts by turbododge and patprimer. Here is a link... if you got some time... check it out...
http://www.eng-tips.com/gviewthread....d/71/qid/72284
Apparently the fine mist... if injected right into the center of the turbo...can work well. As for how perfect it has to be.... I am not for sure. Now maybe my pump and solenoid idea isnt practical... and I can accept that (would be super nice tho!!)... but I dont think there is anything wrong with pre turbo injection except for possible erosion to the blades (this was talked about in the thread), and the general consensus was that it would take years of this becoming a problem. The reality is you are dumping a fine mist, into the nut of the turbo... while it is already at high speed (higher psi)... so the atomized water will likely vaporize before even hitting the turbo. Seems to me that this could further cool the whole intake charge as it goes thru the plumbing. Also I do not plan on using this with stock turbos, so heat thrown out at higher boost levels should be much less.
Before shooting this down.... or something very similar... has anyone had first hand experience or know someone who has with this method? I know it works... unless turbododge and patprimer on eng-tips are lying SOBs.
Rob
Old 03-14-2004, 01:06 PM   #10 (permalink)
dnaxton's Avatar
Drives: 1991 Mitsubishi GTO
dnaxton is an unknown quantity at this point
Hi There,
I am currently running a twin jet Aquamist system.
I have installed a 0.5mm jet just after each intercooler (as recommended by Aquamist UK).
This works great on my car with a 35% methanol/Water mix.
I am currently running 1 bar with no sign of knock at all. I used to see knock creeping in at around 10 PSI.
If your running different boost setting than i am, you will have to play a little and see which size jets will suit your cars setup.
You will also have to play with different water/Methanol mixes.
I started seeing knock with a 50% Methanol/water mix. I dropped the Methanol down to 35% and saw no knock. I have been told that burning methanol produces more heat than burning petrol.
My system is triggered by an adjustable pressure switch which is connected to the inlet plenum and is currently set to activate at 9 PSI.
Have a look at www.aquamist.co.uk
Dave
dnaxton is offline   Reply With Quote
