Where does the power TR unit mount on engine - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-16-2011, 12:09 PM   #1 (permalink)
mitsu lover
jspecmike's Avatar
Drives: 92 Stealth TT
jspecmike is an unknown quantity at this point
Feedback Score: 13 reviews
Default Where does the power TR unit mount on engine
Ever since I bought my car the power tr unit part # J723T has been tie strapped to the fuse box. I want to set things right, someone get a picture please of where this actually mounts to on the engine.
If I have helped you in anyway give me some REP
jspecmike is offline   Reply With Quote Quick reply to this message
Old 08-16-2011, 12:29 PM   #2 (permalink)
Creator of weird stuff...
drgonzo3000's Avatar
Drives: 93RT/TT & 1/2 92R/T
drgonzo3000 Level 1drgonzo3000 Level 1drgonzo3000 Level 1
Feedback Score: 58 reviews
Default Re: Where does the power TR unit mount on engine
The bracket on the right side of the fuse box that goes down and connects to the frame. It connects to one of those holes. Most likely the clip that holds it broke off and the reason for the zip ties!!
From Stealth316
Check it out on Youtube!!
93 Stealth TT - The Stealth Project
Renegade Tech Works ECS Controller on Intrax Springs
Chrome ECU
Hybrid 13g's
EVO 560cc Injectors
Spec Stage 3 clutch
Ninja Performance Output shaft & Input spool
Ninja Performance Solid Tensioner & Gates racing T-Belt
CX Racing Dual Core FMIC
Megan SS Exhaust
Fidanza Cam Gears and Clear Covers
3rd Gen Lifters
HKS BOV
K&N FIPK
Maximal High flow converter
Walbro FP & FuelLab FPR
Maximal and Seattle Solid Mounts
All -6an Lines
Custom -6AN coolant neck lines
AWS/ABS/Cruise Delete
MP Rear Control Arms
SS Brake Lines
99 Front Conversion
2nd gen Rear Bumper
99 Combat Wing
Complete interior LED Swap
Skillard Fuel channel
Oohnoo FPR Bracket
More to Come......
drgonzo3000 is offline   Reply With Quote Quick reply to this message
Old 08-16-2011, 12:36 PM   #3 (permalink)
mitsu lover
jspecmike's Avatar
From Stealth316
I sure hope not lol
Old 08-16-2011, 12:47 PM   #4 (permalink)
Wait... You meant the black transistor that supplies power to the coils right...LOL
Sorry been one of those days!!
Best one I could find!
http://www.stealth316.com/2-pwrtransunit.htm
Also from Stealth316!!!
Old 08-16-2011, 12:53 PM   #5 (permalink)
mitsu lover
jspecmike's Avatar
Stealth 316 - Power Transistor Unit
Yea thats exactly it, that is tie strapped to my fuse box and its driving me nuts lol.
Old 08-17-2011, 01:58 AM   #6 (permalink)
Lovbyts
Paul H.'s Avatar
Drives: 91 Stealth RT TT
Paul H. is an unknown quantity at this point
Feedback Score: 5 reviews
As the picture shows, it's bolts under the coils. Hopefully the steel bracket is there still. You also need to use heat sink grease between it and the bracket.
Intake: WisCo 8.5-1 pistons with enlarged valve clearance, DR-13G turbos, RPS Stage 3 clutch,FIDENZA LIGHTENED FLYWHEEL, Chrome Y-Pipe, K&N Filter Charger, HKS SSBOV, TurboXs boost controller, Krankvents
Ignition: MSD 8.5mm spark plug wires, NGK Iridium BKR7EIX-11 (1 heat ranges cooler than stock) gapped at .032
Electronics: Palm with Pocketlogger software S-AFC
Fuel: PTE 550cc injectors, Denso/Supra 310lph fuel pump, Fuel pump Hotwire kit, relay bypass, Summit Fuel Pressure Regulator, Filter, EK2MFG braided dual feed fuel line kit
Exhaust: EK2MFG EGR Blockoff Plates, DN downpipe, Main cat eliminator flex section, Gutted Pre Cats, Custom Cat back, mufflers and tips
Other: Front & Rear Strut bars, Stillen Cross Drilled Rotors, Custom built, Rear adjustable Camber arms, Pillar mounted Boost gauge, EK2MFG Bling Bling.
Dyno 400 HP ATW
Paul H. is offline   Reply With Quote Quick reply to this message
Old 08-17-2011, 02:40 AM   #7 (permalink)
4L 6G74 Stroker FWD NA
TUFFTR's Avatar
Drives: Mitusbishi Magna
TUFFTR is an unknown quantity at this point
MAKE SURE YOU USE A HEAT TRANSFER COMPOUND! You can get it from electronics retailers commonly used for the back of CPU's to heatsinks. This gets very hot and needs the paste or else you can fry these buggers.
1993 Mitsubishi Magna
- Bored and stroked 11:1 6G74 DOHC (Now 4L)
- Ported heads
- Custom camshafts
- Titanium valvetrain
- Chrome ECU
- One off intake Manifold
- 560cc Evo Injectors/Evo MAF
- Extrators/3" exhaust
- 3000GT 1st/2nd gen brake setup
- Enkei Kojin 18x8.5's
- Rebuild FWD Box with WaveTrac LSD
- E85 Flex fuel Ready
- Evo 3 RECARO's/Ralliart Magna MOMO Steering wheel.
Now to sort out the respray.
TUFFTR is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
