Old 05-01-2008, 02:02 PM   #1 (permalink)
Turbo Lover
edhead81's Avatar
Drives: '92 Dodge Stealth TT
edhead81 is an unknown quantity at this point
Default What's the best way to hoop up my MBC?
I just picked up a TurboXS MBC and I'm itching to install it but first, I'd like to know the best setup for it. I'm thinking of just totally removing the stock boost control setup and running the hose from the back of the Y-pipe to the MBC and out from there to a T-fitting and running hoses from the fitting to the wastegates. Does that sound doable? Is there a difference if the two lines were of different lengths?
edhead81 is offline   Reply With Quote
Old 05-01-2008, 02:05 PM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Default Re: What's the best way to hoop up my MBC?
Yep that's how you do it.
Equal hose length to the wastegates = even boost regulation.
Oh and don't forget to plug the nipple on your rear intake hose after you remove the line from the stock boost solenoid.
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 05-01-2008, 06:35 PM   #3 (permalink)
Turbo Lover
edhead81's Avatar
Good call. BTW, what size vacuum cap will I need for the rear intake hose?
Old 05-01-2008, 08:10 PM   #4 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
I usually put a screw in it. I would guess 1/4" or 3/16" but I'm not sure. Now's a good time to look at dejon hard intake pipes.
Old 05-01-2008, 08:27 PM   #5 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (14)
92RT-TT Level 192RT-TT Level 1
can someone get a picture.. not a diagram showing where said hose that need to be capped on the rear intake hose? Is that one of the two stock lines that normally would go to the stock boost controller?
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Y-Pipe and Intake Pipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, Greddy Turbo Timer.
92RT-TT is offline   Reply With Quote
Old 05-02-2008, 04:31 AM   #6 (permalink)
3SX FTL
Struggly's Avatar
Drives: Viciously
Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7Struggly Level 7
It's in the vacuum hose reduction thread. The vacuum hose reduction: walkthrough and pics
Scroll down and you'll see a photo of the rear intake pipe with the nipple capped.
Clint
The Pansy Patrol
1994 Mazda Protege DX: 253K miles, DOHC 1.8L swap, rear disc brake conversion, poorly-designed header, some cheap-ass suspension upgrades, Carbotech Panther Plus, Miata wheels, other crap here and there, arguably the fastest piece of shit in New England and no one can do anything about it
Struggly is offline   Reply With Quote
Old 05-04-2008, 07:28 PM   #7 (permalink)
Turbo Lover
edhead81's Avatar
I went ahead and installed it, running it inline with the Y-pipe and tee. I deleted the vacuum hoses to the stock boost solenoid and the hose that ran to the rear inlet pipe and capped all the nipples. I retained the stock wastegate lines and tee. I noticed that although the distance to the rear wastegate actuator is much shorter, a large portion of the line to the front is actually hard line and the length of the soft lines for the front and rear are about the same. However, does the length of hose running to and out of the MBC make a difference? I can easily trim a few inches off of them.
I started off with the boost controller fully closed so I was running wastegate pressure (~5psi) and slowly started opening it until it peaked at 13psi.
Old 05-05-2008, 04:30 AM   #8 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
edhead - Sounds good! How does it feel?
To answer your questions, the length of hose coming into the MBC does not really matter - probably shorter is better. The hard line running to your front wastegate can easily be eliminated and replaced with vac. hose in equal length to the hose to the front wastegate - but if you don't feel like doing that, it's fine.
Old 05-05-2008, 09:10 AM   #9 (permalink)
Turbo Lover
edhead81's Avatar
Feels fine. It doesn't feel like it's pulling much harder than before but it's been warm here lately and it's only about a 2psi increase.
Old 05-05-2008, 09:11 AM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
This is on a real boost gauge, correct?
