Old 06-09-2008, 10:06 AM   #21 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Default Re: whats the best turbo for low-mid 11's
Originally Posted by tomwatson View Post
If I recall correctly, I believe he bought it as a turn key car from Dynamic Racing.
Definitely don't call them after that response, or you will be sorry.
correct on both counts
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 06-09-2008, 03:28 PM   #22 (permalink)
Retired
HellBringer's Avatar
Drives: The Bringer of Hell™
Trader Rating: (13)
HellBringer Level 7HellBringer Level 7HellBringer Level 7HellBringer Level 7HellBringer Level 7HellBringer Level 7HellBringer Level 7
Originally Posted by NWrt/tt View Post
hellbringer- if you dont mind, where have you had you car tuned in seattle.
I used to live in FL, but I had a turn-key car from Dynamic Racing. Over the course of a few years I did a lot of additional work to it, though. From a tuning perspective, it was 100% tuned by me with nothing but a Pocketlogger, EGT, G-tech and some open road. I ran 12.0 @ 118MPH on 16psi and pump gas with no traction. The next trip, with 100 octane, I ran 11.6 @ 122MPH at 20psi and then 11.4 @ 125 at 22psi and then got booted off the track never to return... I eventually added a FMIC, CFDS, lighter wheels, better tires, O2 dumps and a few other odds and ends but never went back to the track. Mine was certainly low 11 second capable, even with the stock intercoolers, etc.. My traps may have even been good enough for 10's with a real tire, track prep and madman driving.
There aren't many low 11 second TD04 cars out there, but there are a lot of 16g cars running slower times than I did 4-5 years ago on TD04 peashooters.. 16g's don't automaticlly equal low 11's or better...
2002 Z06 Garage Queen | 1994 Supra TT Garage Queen 2 | 1999 3000GT Daily Beater
Formerly:
1992 Stealth RT/TT
1993.5 Supra TT
1993 3000GT
1992 3000GT VR-4 11.4 @ 124MPH
1998 Trans AM WS6
1992 Talon TSi
1993 3000GT VR-4
HellBringer is offline   Reply With Quote
Old 06-09-2008, 04:40 PM   #23 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Dont go to places that flippantly think they can work on a 3S that never has, and def dont go to a place that has and will not touch them although the latter are pretty smart but just might not be good enough. Being a parts installer is easy on alot of imports because they are cookie cutter and usually, its easier to work on a new car thats working perfectly. The 3s cars are old and need to be working well in a base line before mods are thrown at it. This is something the kids cant afford to have a shop do, but what is often done with domestics right off the bat unless they are replacing everything anyway which you cant really do with these cars so easily on the cheap. Learn to work on it yourself, and do the free mods and get the car to optimum stock condition, then look for more power. If your not familiar with the car, then trying to take the car from 13s(or whatever its doing) to 11s in one shot is not that wise
wraith is offline   Reply With Quote
Old 06-09-2008, 05:20 PM   #24 (permalink)
NWrt/tt is an unknown quantity at this point
thank you for the input but as i have said im rebuilding. i decided on a set of 19t's
NWrt/tt is offline   Reply With Quote
Old 06-09-2008, 07:30 PM   #25 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
i will also take your car and install the 19t's i make and install all necisarry fuel mods and tune it for you. on the new mustang dyno.
houston texas is where im located if interested.
markoverclock is offline   Reply With Quote
Old 06-09-2008, 09:25 PM   #26 (permalink)
Drives: 2 stealths of course
TikiFerrari TikiFerrari TikiFerrari
what turbos did you have? dr650's ?
TikiFerrari is offline   Reply With Quote
Old 06-09-2008, 10:08 PM   #27 (permalink)
Retired
Trader Rating: (13)
DR650's w/ Stage II heads
Abram P - Dynamic Racing
The modlist on DR's site includes some parts that were added after I ran the above-listed track times.
Old 06-10-2008, 01:49 PM   #28 (permalink)
im in washington, thanks anyways
Old 06-11-2008, 02:08 PM   #29 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (41)
DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4
Originally Posted by Trevor View Post
Hardly anyone runs low 11's on TD04's.
Bullshit. Ray and Jack did. What % is that of total 15G runs?
Yes, sarcasm.
DJAuggie is online now   Reply With Quote
Old 07-09-2008, 11:21 AM   #30 (permalink)
1st NG08 / 2nd NG07 Drags
Drives: 93 VR-4
neverenoughhp Level 2neverenoughhp Level 2neverenoughhp Level 2
Scott Johnson ran 11.3 on pump gas DR-500s. I have run 11.8 without traction and hot lapping; i'll prob hit 11.5 or so when i get back to the track. Im seeing a lot of talk about hp; where is the talk about traction, weight distribution, overall weight, diffs, driveline effeciency, etc.
My rec if you want to road race, drag race, and dd is DR 16Ts, heads, and sig weight reductions. Also the widest tire you can put on it, cf driveshaft, front lsd, and good suspension setup. dont think that the only way you can cut weight is by destroying the car. You can easily cut 400 lbs. By going this route you can hit 11.6-11.7 on race fuel without needing a shit ton of hp. Then you keep good idle, easy to tune, good gas mileage, very minimal lag, etc. On a road course you have to accelerate, slow down, and turn weight - get rid of it.
11.6 @ 124 w/DR-500s
neverenoughhp is offline   Reply With Quote
