#61 (permalink) | |
165 mph and counting...
PM TurboBob, I think he bought one, and he could detail the changes better than I. As far as I know though, we don't have any "improved" parts we can just slap on our engines. A high volume oil pump has been on the wish list for many of us for years, for now, we only have Supercar's custom oil pan. It certainly doesn't hurt to have it, but I think our main problem is with oil delivery, not supply.
![]() 1991 Stealth Twin Turbo Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley. |
#62 (permalink) | |
However I am positive that for an engine that will never see above 25 psi of boost, crossdrilling a crank would have no ill effects with warping or cracking. If the stock crank can handle 30+ psi on numerous drag visits with shots of nitrous on top of that as proven by 3SX, I think my solution would be perfect. |
#63 (permalink) |
"We were able to get the car on the dyno today. We battled knock all day and just found that your knock sensor had a short in it and was randomly grounding out"
"We encountered an issue today during dyno tuning. Despite running only 8PSI and AFR's in the 10's, your car has developed a lower end knock. At this point we will not be able to dyno tune the car until this issue is resolved." Thats all I know from the tuner. The car drove fine to the shop, other than the idle being a pain and an exhaust leak. I didn't rev high or run more than 5-6psi. I wasn't logging knock on the way there, as I had just replaced the clutch and apparently during the process managed to scuff the knock sensor wire. Tuner did fix this however, so I would assume they were logging knock. Anyways, I won't know until I or the machine shop disassembles the engine. Anyways, cross drilling the crank could be worth a try. I'll have to defer that to the machinist though, as machining is not my area of expertise.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, Titan Headers w/ Big TD05 16G Turbos,
#64 (permalink) |
I personally have experienced the post spun bearing rebuild to immediate spun bearing. I had replaced only the rod that had spun (#4). All other rod bearings were found to be worn evenly during the tear down. Clearance checks (plasti-gauge--yes, I know it's not perfect) with turned crank (forged), showed within book specs. Completed assembly, started engine, idled for 5 minutes, drained oil. Replaced filter, refilled oil, took for short drive. 12 miles, and my engine started making the stangest racket. Removed oil pan, found excessive play in #1 rod. Tore motor completely down and found that bearing had spun again. Sent all rods and crank to machinist. Machinist had found that rods were out of round----not top to bottom but side to side. He did find that to be very curious. Possible that is clearances were checked with plasti-gauge, and not by micrometer and/or calipers, that you may very well have had an out of round issue. By the way, 3 of the rods were out of round in this way--- .002 greater clearance side to side, than top to bottom.
Personal lesson, for me, is to always have every rod resized with the crank that I will be using. |
#65 (permalink) |
Forest Gump
This wouldn't have anything to do with engines that seem to spin bearings under low load, but it is an idea.
We know that our rods are fairly strong and can hold as much as 600AWHP for quite a while without fairly if you do not knock. Maybe though, before the rod actually fails it is flexing enough to distort the shape of the bearing and bam spun bearing. Just an idea...
![]() Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Looking for 2nd gen Stealth or 3000GT rear bumper my sideskirts and door caps for sale, PM me. |
#66 (permalink) |
Could be the case. I do know the machinest used a caliper. However you may be correct, maybe it is best to just replace all the rods anyway. In this next rebuild its going to be very through and through, if I have to stand over the person doing the machining. For sure I'll see if there aren't any other ways to increase oiling to the bearings too, such as the crossdrilled crank.
#67 (permalink) | |
Livin' the dream
![]() 1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)... 1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT |
#68 (permalink) |
Corn Its whats for boost
which rod did you spin last time?
AEM Factory Trained Tuner
![]() 91VR4 Black-5027s-3.0L-Stock heads and Cams- 707AWHP 620AWTQ uncorrected 30psi E85 Daily Driver SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold 3SX Performance 3SX Performance Service Email |
#70 (permalink) | |
91 Stealth TT
![]() Currently a member of the Spun Bearing Club -15G's, MBC @ 7psi -ARP Head Studs, Ported Heads -.80 Ross 8.5:1 Pistons & Crower Connecting Rods -RPS Street Max Clutch & Pressure Plate -ESP Downpipe, Gutted Cats, EGR Blockoffs -3SX Polyurethane Motor Mounts -Hotwired Supra fuel pump, Resistor Bypass -Fuel Labs AFPR @ 44psi -Dejon Dual Intakes -MAFT-Pro in Speed Density |
| Thread Tools | |
