#51 (permalink) | |
Cant get there from here!
This may also explain why the person who has the custom pan doesnt have any troubles. Just a thought to try to get to the bottom of this. -SP
![]() One of 789 |
#52 (permalink) |
Play that Funky Music
I have seen bearings spun many times on engines that spun in the past and just the bearings were replaced. Old rod and crank left in the car. Seen that more than once.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold 91VR4 Black-5027s-3.0L-Stock heads and Cams- 625AWHP 557AWTQ uncorrected 24psi 102 octane Daily Driver 3SX Performance 3SX Performance Service Email |
#53 (permalink) |
Ok, I am by far no expert on this, but I do have an idea. In this dangerous "break-in stage" would it at all help to change the oil more frequently like say 1500 to 2k miles instead of 3k. There's been the statement it could be debris in the oil that wasn't cleaned on the rebuild... could changing the oil more frequently help this problem?
#54 (permalink) | |
Livin' the dream
![]() 1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)... 1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT |
#55 (permalink) |
mc.noob
I am kind of anal but whenever I do anything where dirt can get into the oil...ie heads off, rocker covers off, oil pan off etc. I make sure all crap is out of the oil. I run an organic oil for a few minutes and drain it/replace filter. I replace it with the same oil and filter and drive it for a week. then I drain that and replace it will my regular filter/synthetic combo. To me, oil is cheap. Might be overkill but I sleep well at night
#56 (permalink) |
Its always a good idea to change the oil after running the engine shortly. This will hopefully remove anything left after the cleaning process. I ran my engine for a short time, changed the oil, then changed it at 1K, then again at 3K. One thing I have noticed is that I've never came across a stock engine that has spun the bearing under 100K. It has always been rebuilds. Only thing that makes it really expensive is when it turns badly on the crank, then you have to pay a god awful price for a new one. I can't think of any one local I would trust trying to rebuild/turn a crank that had spun the bearing.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, KOYO Aluminum Radiator
#57 (permalink) | |
165 mph and counting...
My current car has a stock shortblock, with 91k on it now. Only time I've ever opened the engine was when I took the heads off after my adjustable cam gears slipped a bit and the valves hit the pistons just slightly on #3. If I do spin a bearing, and I decide to keep the car, I will be going with a forged crank and I will have it crossdrilled. I also thought about using two rod bearing sets, and just using the "grooved" sides, but I think that dramatically cuts down on surface area needed.
![]() 1991 Stealth Twin Turbo Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley. |
#58 (permalink) |
I'm only referring to the cars that I've worked on in person, or some of my own. Yeah, I'm aware of this bearing issue with others though on lower mileage blocks. It would just be nice if we can get some ideas together maybe even get a vendor involved in R&D to see if there is and economical way to solve bearing issues, and a spun bearing trashing the crank.
#59 (permalink) |
Nobody`s mentioned knock yet, I think a factor of poor maintainance and turning up the boost without datalogging cause a lot of crank bearing failures.
When the OP had the car on the dyno was he logging knock?.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - Gutted MAS - K&N Blitz SSBC - Aquamist Water Injection |
#60 (permalink) | |
Livin' the dream
| Thread Tools | |
