What Is This? And Advice on How to Add GM/MAF - Pics! - Page 5 - 3000GT/Stealth International Message Center
Old 01-21-2013, 02:53 PM   #41 (permalink)
Always Learning
mikeyVR4's Avatar
Drives: 2013 WRX Prem 4D WRB
mikeyVR4 is an unknown quantity at this point
Feedback Score: 8 reviews
Default Re: What Is This? And Advice on How to Add GM/MAF - Pics!
Was able to get the hose on. I basically used a Dremel and filed down the inside of the coupler a bit.
mikeyVR4 is offline   Reply With Quote
Old 01-21-2013, 07:54 PM   #42 (permalink)
beasting's Avatar
Drives: stealth
beasting is an unknown quantity at this point
Feedback Score: 9 reviews
Originally Posted by striker3 View Post
he is saying that his sensor has ACDelco and some part numbers on it, where as the one you posted has no numbers on it.
sorry i have the habit of speed reading..
i didnt know GM made all plastic sensors like the one that came with your kit, i always thought that they had metal ends and the plastic part in the middle...
unless GM changed the design and ACDelco made a better more accurate sensor..
93 SOHC: headers, intake, exhaust, heads, and a bunch of usless stuff.
92 VR4: blow thru, stillen dp, exhaust, safc+maft, mbc set at 20 psi, water/meth,
298 awhp 343 awtq
beasting is offline   Reply With Quote
Old 01-23-2013, 04:06 PM   #43 (permalink)
Always Learning
mikeyVR4's Avatar
Question.
Does anyone know what the tube is that is coming from the intake manifold to the pre-turbo piping for the rear turbo?
Old 01-23-2013, 04:20 PM   #44 (permalink)
From KDM to JDM
Keyan's Avatar
Drives: Red 93 VR4
Keyan Level 1Keyan Level 1
Feedback Score: 31 reviews
i took pictures just for you ill upload them when i get home.
also i am unsure of what hose you are talking about.
TD04HL-19T:
435hp <--broken fuel...NOT FINAL NUMBER.
TD04L-13G:
421awhp/419awtq @ 17psi tuned by Pampena Motorsports ....375awtq at 2900rpm....
12.2sec @ 116mph, 18psi on a mix of race and pump.....and only a 1.9 60 foot
Keyan is offline   Reply With Quote
Old 01-23-2013, 04:23 PM   #45 (permalink)
Always Learning
mikeyVR4's Avatar
Awesome thanks!!!
Yeah I am waiting for my reducer hose from that website you provided and its on its way. I am also about to order my TDO4 dejon pre-turbo pipes but curious if I need the charcoal canister nipple and the Air Nipple for the boost control solenoid.
I will see if I can get a picture up to show you what I am talking about.
Old 01-23-2013, 04:39 PM   #46 (permalink)
Always Learning
mikeyVR4's Avatar
I pulled this engine bay picture from the internet. That tube/vacuum is what I am curious about? Can I simply just put a air breather filter on that?
I am wondering if that is the Air nipple for the boost control solenoid...?
What Is This? And Advice on How to Add GM/MAF - Pics!-96vr-4-enginebay-feb04.jpg
Old 01-23-2013, 05:00 PM   #47 (permalink)
mtonkin6's Avatar
Drives: 92 GTO TT
mtonkin6 is an unknown quantity at this point
Feedback Score: 0 reviews
If u followed the hose u will find it goes to ur bov
mtonkin6 is online now   Reply With Quote
Old 01-23-2013, 05:08 PM   #48 (permalink)
Always Learning
mikeyVR4's Avatar
Nah thats the hose at the top of the intake plenum. This hose goes to the pre-turbo pipe for the rear turbo.
I will get a better picture when I am off of work.
Old 01-23-2013, 05:39 PM   #49 (permalink)
Always Learning
mikeyVR4's Avatar
Here are the pictures. Is this the Air nipple for the boost control solenoid?
Old 01-23-2013, 10:41 PM   #50 (permalink)
beasting's Avatar
Drives: stealth
Sir that is a vacuum source for your crankcase pressure evacuation
It provides vacuum to relieve crank case pressure when your pcv is closed
