Old 07-04-2008, 09:52 PM   #1 (permalink)
Drives: 1992 Dodge Stealth
JayWilRTTT is an unknown quantity at this point
Default weird arc 2 problem need ideas
My car was running great. I parked it for a couple hours for a cookout and when I went to start It ran like crap and shut off. So I looked at my arc 2 controller and noticed that I had moved the settings as I got into the car. So easy enough I put them back and the car runs terrible. It doesnt make sense it was idling great before. I've moved the setting before on accident and never had this happen. The car will not idle, the arm-1 02 gauge shows that the car is always running rich. It will not dither back in forth at any RPM and the only way to drive is to keep my foot on the gas. On the highway it ran ok and under accel but at low speed or idle it bucks and shuts down. It doesnt make any sense, and while driving it I tried adjusting the settings and it doesnt help. I'm still getting an airflow signal on my scanmaster3. The car does react to changing the MID setting which always stays set at -7clicks. Please help I need ideas for troubleshooting. Did I damage one of the pots in the ARC 2 unit by turning them accidentally?
JayWilRTTT is offline   Reply With Quote
Old 07-05-2008, 11:48 AM   #2 (permalink)
Default Re: weird arc 2 problem need ideas
hey no ideas? Snakeskinner?
Old 07-05-2008, 12:20 PM   #3 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
you could have a bad factory o2 sensor, your factory IAC could be bad, the maf unit may have gone out or the arc2 controller could have a bad contact (which has NEVER happened).
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED NINJA TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 07-05-2008, 01:52 PM   #4 (permalink)
both front and rear o2's giving me rich condition. IAC value changes when you turn on the ac and goes back when turning ac off. I'm still getting airflow signal from the maf according to the scanmaster 3. I doubt both O2's went bad. Like I said the car has been running great with my new TDO5 setup. I didnt beat up on it before I parked or anything. All I did was turn off the ignition. When I started the car with those wrong settings in ran terrible and then cutoff. The accel settings were at like 16% and the High moved to -12%. I then put the settings back to normal which is
Low+2clicks
Mid -7
High-1
Accel+2
and will not idle and it smells rich even in the car.
Old 07-05-2008, 04:10 PM   #5 (permalink)
j sin
gltasn's Avatar
Drives: 95 mitz 3kgt vr4
gltasn Level 3gltasn Level 3gltasn Level 3gltasn Level 3
i have my tdo5/720's running with a setting of +2,-8,+4,+2. you can try turning off battery for 10 min and it will reset the ecu. good luck! j sin
"If I was as slow as you, they'ed bury me!" terry canfield(dad)
gltasn is online now   Reply With Quote
Old 07-06-2008, 09:28 PM   #6 (permalink)
anymore ideas?
