vr4 boost problem jerks under boost - 3000GT/Stealth International Message Center
Old 01-29-2013, 01:28 PM   #1 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
That3000gt Negative 1
Feedback Score: 0 reviews
Default vr4 boost problem jerks under boost
Happens in third gear and up did vac reduction and egr thought it might helped happend when i did a fmic and i forgot to plug waste gates up did the same thing that jerk under boost mods are full exhaust intake sqv bov just put new plugs in they were gapped for .40 so i put the new ngk coppers at .30 and had boost mod done but went back to wastegate any help is apprieated thanks video is below
https://www.youtube.com/watch?v=2tfM...e_gdata_player
That3000gt is offline   Reply With Quote
Old 01-29-2013, 02:06 PM   #2 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
Default Re: vr4 boost problem jerks under boost
At 4000rpms and up under full boost
Old 01-29-2013, 05:42 PM   #3 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
Also when in high gear and your low on rpm and you try to give it gas it will like bov will go on and off on and off and you can hear air like backing in and out of the tubes on the bov
Old 01-29-2013, 06:28 PM   #4 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
All these views and nobody knows come on ill take whatever help i can get
Old 01-29-2013, 11:14 PM   #5 (permalink)
Escape-Performance's Avatar
Drives: lots
Escape-Performance is an unknown quantity at this point
Feedback Score: 8 reviews
Do you have an aftermarket boost gauge? If so what is it doing and how much boost are you running. Probably boost blowing out a ic pipe. Could be a bad bov as well. If you don't have a gauge or data logger all you can hope to get is educated guesses.
Not using sentences makes it hard to understand what you are trying to say and some may simply not bother figuring it out.
Single Holset HX52 with custom quick spool valve
Escape-Performance is offline   Reply With Quote
Old 01-29-2013, 11:21 PM   #6 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
I have it as waste gate now and no I will get a boost gauge tmr.and sorry about not using periods I was in a rush thanks for the responce
Old 01-29-2013, 11:26 PM   #7 (permalink)
Ancient Spirit Of Evil
kelvinTurbo's Avatar
Drives: Mumra tank
kelvinTurbo is an unknown quantity at this point
Feedback Score: 1 reviews
spark blowout?
wastegates jacked up?
would like to know AFR at moment when it happens, that would give us an indication of state of tune and whatnot
do you have FMIC? in some cars FMIC can cause those symptoms
Ancient spirits of evil, transform this decayed form into Mum-ra!!
Your girl kissed me on my neck, then kissed me on my chest... and then she... took it to the head yeaay yeaay! no excuses no apologies she's all about it
kelvinTurbo is online now   Reply With Quote
Old 01-29-2013, 11:30 PM   #8 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
Yeah I don't have a gauge I was trying to figure out if it was boost solenoid so I went to wastgate boost. Was trying to find out if it was spark blow out or fuel cut also has a popping when u let off throttle it pops and at idle it pops I can post a video.
Old 01-29-2013, 11:31 PM   #9 (permalink)
That3000gt's Avatar
Drives: 91 vr-4
Did you watch the video?
Old 01-29-2013, 11:34 PM   #10 (permalink)
MechanicalShutdown's Avatar
Drives: 97 Mitubishi GTO
MechanicalShutdown is an unknown quantity at this point
Feedback Score: 4 reviews
When did it start? Has it been sitting around for a while?
Sent from AutoGuide.com App
MechanicalShutdown is offline   Reply With Quote
