So, I finished dropping the engine back in my VR-4 from having the heads off for a valve job. I went to start it up and it takes a bit longer than usual to start and cranks a little bit slower than normal. When it does catch, it either fires off a few times and dies or does one quick rev to ~1500 rpms and dies. I was able to get it to stay on for a bit by giving it some gas, but it ran really rough and low, even with 50-75% throttle. It did this for several seconds, then it revved to around ~3500-4000 rpms really quickly. I had my hand on the key and scared the piss out of me, so I shut it off out of instinct. Things of note:
-I checked the timing and it was on every mark before I dropped it in
-I had an issue with the car trying to start itself when the battery was connected, but it was resolved. I only attached one of the wires by the starter and missed the smaller one. Trying to find out the problem caused me to flood the engine, so I pulled the front plugs and let it sit over night. No change, so I replaced the plugs. Still no change.
-I have a couple connecters that I'm not sure of what they connect to. There is no other connecter anywhere near that I can find. One is below the passenger headlight. The other is near the power steering pump.
-OEM MLS headgaskets were used. No milling was done as the machine shop said the heads looked fine. A scraper was used to remove the old gaskets residue. It was about the smoothest thing I've ever felt before I put the gasket on.
-Whenever it turns on, the garage gets very smoky and there is a very burnt smell. I can't see any origin for the smoke. It's just smoky all over.
That's all I can think off the top of my head. Any other questions, just ask. Any help would be great. I'm tired of not being able to drive her.
