Old 12-24-2007, 11:33 AM   #1 (permalink)
Cougar Hunter
EMC 3000GT's Avatar
Drives: '92 3000GT FWD TT
Trader Rating: (9)
EMC 3000GT is an unknown quantity at this point
Default Unmarked warning light?
I got this question on another forum and I am completely stumped.
"I don't know exactly what this warning light means, but i believe its the radiator warning light. I have search the net for help, but everything i find has this single light omitted.
Any help will be appreciated as I'm not 100% sure what it is. Its located in the center cluster of lights, down in the last row and to the right."
BTW it is a GTO MR.
EMC 3000GT is offline   Reply With Quote
Old 12-24-2007, 01:18 PM   #2 (permalink)
GTO03 is an unknown quantity at this point
Default Re: Unmarked warning light?
Hi
i think it's the light for the catalytic converter!
francois
GTO03 is offline   Reply With Quote
Old 12-26-2007, 02:58 AM   #3 (permalink)
Drives: 1990 GTO
aussie_will is an unknown quantity at this point
This thread might help: Unidentified sensors in exhaust of a '91 GTO
Cheers,
Will.
aussie_will is online now   Reply With Quote
Old 12-26-2007, 10:58 AM   #4 (permalink)
Cougar Hunter
EMC 3000GT's Avatar
Trader Rating: (9)
Thanks guys!
Old 12-26-2007, 11:28 AM   #5 (permalink)
Car PC Tech
njrbd's Avatar
Drives: 94VR4 95SL 96GS 97M3
Trader Rating: (11)
njrbd Level 1njrbd Level 1
Means your exhaust smells J/K
njrbd is offline   Reply With Quote
Old 12-26-2007, 08:00 PM   #6 (permalink)
Tys
Drives: 96 GTO
Tys is an unknown quantity at this point
My JDM GTO also displays this light. If it is the catalytic converter is it a serious problem that the light is displayed? Is it really something that i should be worried about, or is just telling me that there just are more emissions coming out of my GTO's exhaust?
Tys is offline   Reply With Quote
Old 12-26-2007, 08:39 PM   #7 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (28)
Highboosted Level 2Highboosted Level 2Highboosted Level 2
main Cat overtemp warning light. means there is something wrong causing the main cat to overheat and possibly damage it. Most likely running too rich/missfires, excessive retarded timing, or excessive exhaust restriction.
[edit]: I'm an idiot. Other thread said that, too.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Tech inspector: "What's that for?"
Me: "It makes me win".
Tech inspector: "How?"
Me: "By confusing people who try and copy me".
Highboosted is offline   Reply With Quote
Old 12-26-2007, 09:44 PM   #8 (permalink)
Tys
Drives: 96 GTO
But the weird thing is that it appears as soon as the car starts, so it shouldn't be overheating. So does that mean its damaged? Or is the sensor just damaged?
Old 12-30-2007, 06:53 AM   #9 (permalink)
SlowTT
slow91stealth's Avatar
Drives: not right now
Trader Rating: (28)
slow91stealth is an unknown quantity at this point
it turns off after you atart the car? how long after? if its just a few seconds its just the ecu running a test on the sensor and nothing to worry about. but if it turns on and stays on the sensor is bad, or the cat is so bad that the sensor cant read and right away it sees a bad cat
My Car: 1991 Dodge Stealth RT/TT Pearl Metallic White
My Mods: FMIC(front Mount InterCooler) w/ Greddy RS Type BOV, Walboro 255 Fuel Pump ,IPO Fuel Pump Install Kit, IPO Fuel Pump Hotwire Kit ,EK2 Fuel Loop(not installed), Blitz FATT Turbo Timer ,KYB GR-2 Struts, TEIN S-Tech Lowering Springs, Power Slot Rotors and Pads, 3x 52mm Tripple Pillar Pod(not installed), AEM UEGO Wideband O2, AEM TRU-BOOST Boost Controller, Topline Engineering Ground Wire Kit, Accell Sparkplug Wires, NGK Iridium Sparkplugs, General Denastification(vaccum reduction), Powdercoated Gloss Black and Polished Lettering Valve Cover/Intake Manifold, Polished Sparkplug Cover With Red Lettering Comming
!!!FOR SALE!!!- PM me for more info
slow91stealth is offline   Reply With Quote
Old 12-30-2007, 02:24 PM   #10 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
Cheers,
Will.
Hmmmm... Learn something new every day. Maybe this should be added to the Wiki.
