Old 07-06-2008, 06:20 AM   #1 (permalink)
GTO68's Avatar
Drives: 3000GT VR-4
Trader Rating: (8)
GTO68 is an unknown quantity at this point
Question Twin walbo and hotwire?
HI all,
I have a litlle ..litlle question! I have twin walbro in my fuel tank and i would like to know if i need one or two hotwire?
Thank's..
Saf
Powered By Pampena Machines
GTO68 is offline   Reply With Quote
Old 07-06-2008, 06:33 AM   #2 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (7)
defgh1 is an unknown quantity at this point
Default Re: Twin walbo and hotwire?
Originally Posted by GTO68 View Post
I all,
Thank's..
Saf
I would say yes since the current draw of two pumps will be putting a lot of strain on the stock circuit. However, more importantly have you increased the size of the fuel return line? The output of the dual pumps will overflow the pressure regulator without a larger return line. I assume you have installed a larger output line from the pumps, then you can adapt the stock feed line as the return to the tank and you should be OK.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 07-06-2008, 06:43 AM   #3 (permalink)
GTO68's Avatar
Drives: 3000GT VR-4
Trader Rating: (8)
Doug H
Thank's Dough , but you don't understand my question!
I already have all fuel line in my car My problem come from the hotwire look:
For the moment , i have one hotwire for twin pump and now is broken and i would like if i need one hotwire for each pump!
Saf
Old 07-06-2008, 06:55 AM   #4 (permalink)
Senior Member
defgh1's Avatar
Trader Rating: (7)
You should not need an additional hot wire but I would pick up a high current Stereo fuse and holder to handle the higher current.
Doug H
