Old 04-06-2008, 11:04 PM   #1 (permalink)
Staying in the Family
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (12)
jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7jandoaudio Level 7
Default TT head differences between years
I am trying to determine the differences and compatability between first and second gen tt heads and have gotten varying answers.
My understanding is that the CAS is mounted in different locations on 2nd gen heads than it is on first gen heads. That said, are there mounting points on both heads making them interchangeable or are they generation specific? If so, what is involved to convert from one CAS to the other?
I have a set of ported, polished, larger valve heads I would like to pull from my 92 to put on my 95.
Thanks for the help,
Clayton
95 RT/TT Stock
92 VR4 Blacked out with a 98 conversion
dr900's
Stage 3 Heads
98 Jeep TJ
35's
Locked with all the toys
Cheap, Fast, Reliable.... You can only have two
jandoaudio is offline   Reply With Quote
Old 04-06-2008, 11:11 PM   #2 (permalink)
91 RT/TT
EvanH's Avatar
Drives: 91 RT/TT
EvanH is an unknown quantity at this point
Default Re: TT head differences between years
I thought the CAS was in the little area between the heads and had nothing to do with them? Unless thats the knock sensor. I think heads are interchangeable.
EvanH is offline   Reply With Quote
Old 04-07-2008, 01:02 AM   #3 (permalink)
mitsuman3000's Avatar
Drives: 3000 VR4 & Talon TSI
Trader Rating: (6)
mitsuman3000 is an unknown quantity at this point
Here is a link on what is involved on converting the CAS.
http://stealth316.com/0-frames.htm also this site has a LOT of useful info on it for our cars.
go to the "garage" section and look under "conversions" then "CAS"
mitsuman3000 is offline   Reply With Quote
Old 04-07-2008, 10:10 PM   #4 (permalink)
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (12)
I never even thought to check jeffs page Thanks, thats exactly what I was looking for.
Old 04-07-2008, 10:52 PM   #5 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (23)
Monster Stealth Level 1Monster Stealth Level 1
It can be done, but if you run 92 heads on a 95 you have to use that year/style cam/crank sensors. I am running 91-92 heads in my 93.
Performance
6G72 Rebuilt w/ 3SX Stage 3 Heads (+1mm intake/exhaust) - ARP Headstuds, Wiseco 8.5:1 Forged Pistons & Kevlar Timing Belt - TD04 9B - Greddy Profec B Spec 2 Boost Controller – Greddy Turbo Timer - SSQV BOV - K&N FIPK - Dejon Tool Y-Pipe - Dejon Tool Intake Pipes - OEM 360cc Injectors - IPO Hotwire Kit - EK2 Fuel Rail Loop – eBay 3” Downpipe w/ custom Flex Section - IPO UD Pulley – RPS MAXX Street Clutch - Maximal Xcase Bracket - MSD 8.5mm Plug Wires - NGK Copper Plugs - Maximal Performance Front & Rear Solid Motor Mounts - 3SX EGR Block Off Plates - Vac. Reduction - AC Delete – Cruise Control Delete - ProSport Gauges (Boost, EGT) - Odyssey PC680 Under Fuse Box
Sitting in garage: EVO 560cc Injectors - MAP ECU - WRX 13T Turbos - Krank Vents - Walbro 255
Suspension/Wheels/Brakes
OEM 17” Chrome Wheels – 245/45/17 Michelin XGT Z4's
Sitting in garage: RS*R Springs – Bilstein Struts – Maximal Adj Control Arms
Exterior/Interior/Dress-up
Autometer 2x52mm Gauge Pod - 99 Rear Center Garnish – Weevil Custom Boost Controller/Turbo Timer Mounting Plate – Snake Eyes Delete Sylvania Silverstar H4666ST – Powder Coated Upper/Lower Intake Manifold, Front/Rear Valve Covers, Y-Pipe, Waterneck, & Alternator Bracket
6G72 Engine Manual - M-Spec Vac Reduction Diagrams - My Picasa Web Album
Monster Stealth is offline   Reply With Quote
Old 04-15-2008, 05:49 PM   #6 (permalink)
Trader Rating: (6)
No prob, that's what the community is for
Old 04-17-2008, 04:46 PM   #7 (permalink)
Drives: 3000gt VR4
Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7Patryn Level 7
I threw a set of 1st gen heads on my 1995, just used second gen internals, and made a bracket for the cam angle sensor on the drivers side. Other than that no problems swapping 1st gen heads to a second gen.
1998 VR4: SS Downpipe, Borla Cat-Back, Open Element Air Filter, ACPT CFDS, DN Intake Pipes, Front & Rear Strut Tower Bars, Deftracing 575 Hood, Blitz DSBC, Vacum Redution, Krank Vents, KOYO Aluminum Radiator
Patryn is offline   Reply With Quote
Old 04-18-2008, 08:52 AM   #8 (permalink)
jandoaudio's Avatar
Drives: 95 RT/TT
Trader Rating: (12)
My understanding from Jeff's page is that timing will be off a few degrees if I use the first gen CAS on my second gen ecu.
Patryn, what did you do for a bracket? I haven't had the heads side by side to compare them yet but I would assume its fairly simple.
Thanks again!
Old 04-18-2008, 04:03 PM   #9 (permalink)
Drives: 3000gt VR4
Its not hard, just get a few pieces of aluminum or plate steel whatever, cut it weld to make a bracket. If I get the engine out of the car I'll snap a pick of my setup so you can see. Also, if you wanted to have a shop make a bracket for you they should probably be able to make one from scartch in two hours tops with both heads in hand.
