Old 05-23-2008, 11:33 AM   #11 (permalink)
95gto's Avatar
Drives: 95' VR4
95gto is an unknown quantity at this point
Default Re: TruBoost Post-install question.
If your boost pressure is reading improperly:
-check your connections, mechanical and electrical
-check your sensor type, should be internal
-check your display units, make sure it's set to psi
Mine was very accurate compard to both a different boost controller and a boost gauge.
95gto is offline   Reply With Quote
Old 05-23-2008, 03:58 PM   #12 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j Negative 3
I'm 99% sure its my hoses. I'm gonna take another close look tomorrow. (will change my injectors at the same time). and I'm pretty sure i'll be fixed. will see.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump.
Working on: Driver mod. Paint job!! finally.
E85 powered VR4
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
I want more red!!!
a2j is offline   Reply With Quote
Old 05-23-2008, 07:14 PM   #13 (permalink)
MrWallyvr4
mrwallyvr4's Avatar
Drives: single Turbo stealth
Trader Rating: (58)
mrwallyvr4 Level 1mrwallyvr4 Level 1
50+ psi I should of changed that before I shipped it to you. lol
and hell yes these are great boost controlers/readers
Never argue with an idiot. They drag you down to their level, then beat you with experience
mrwallyvr4 is offline   Reply With Quote
Old 05-23-2008, 09:19 PM   #14 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (15)
92RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 692RT-TT level 6
haha I hope they are good ones. My Stealth is getting one put on tomorrow night
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust.
DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08
92RT-TT is online now   Reply With Quote
Old 05-24-2008, 09:03 AM   #15 (permalink)
a2j
a2j's Avatar
Drives: Red Car
a2j Negative 3
oh, I knew it!!!! almost blew up my engine cuz of that.
but anyway, I'll try to program it again. if I'm not getting fuel cut or knock, I'm not pushing 50+psi, thats for sure.
Old 05-31-2008, 02:49 PM   #16 (permalink)
a2j
a2j's Avatar
Drives: Red Car
a2j Negative 3
I hooked it up to the hose that goes towards the firewall, is that a good place for it?
edit: ok I think I got it.
my problem was Units. (duhh!!). it was set to PAS (Kpg), instead of PSI. (dumb ass)
any way. my (hopefully) last questions:
can I set my spring pressure lower than 6?
and how exactly do you adjust boost? buy wasted gate or boost settings. I can't get boost setting lower than 10, is it normal? can I possibly run 3psi. just a question.
Old 06-02-2008, 07:42 PM   #17 (permalink)
a2j
a2j's Avatar
Drives: Red Car
a2j Negative 3
anybody?
Old 06-03-2008, 08:40 AM   #18 (permalink)
95gto's Avatar
Drives: 95' VR4
The hose that comes off the back of the plenum toward the firewall is perfect to t'ing in your boost gauge line for the controller.
You can adjust spring pressure lower if you want, it will slightly increase the time it takes you to build up to your set boost pressure as you take the setting lower and lower. Most people run a low setting though to offset lead in boost spike.
You adjust boost by increasing the axx or bxx setting, so you just simply increase the number for that boost mode. You are actually increasing or decreasing the duty cylce of the solenoid for the boost mode when you adjust that number. So increaseing A10 to A25 is actually increasing the duty cycle of the solenoid from 10% to 25% for boost mode A. Duty cycle range for the controller is 10% to 90%, so your lowest value would be A10 and highest value would be A90.
You cannot run lower boost than wastegate pressure, so nothing less than ~6-7psi. Also this is why as you slowly increase the duty cycle for a specific boost mode you won't see a change in boost pressure until you reach a duty cylcle value large enough to increase boost pressure over wastegate pressure. If I remember right you should start to see an increase in boost pressure somewhere around a setting of 25% duty cycle for stock turbos. But always just start low and slowly increase the duy cylce. I used increments of 5 until I hit about 9psi and then slowed to smaller incremental increases until I found my target boost setting.
Old 06-07-2008, 10:46 PM   #19 (permalink)
a2j
a2j's Avatar
Drives: Red Car
a2j Negative 3
I can't get more that 6.5 psi. my duty cycle is 50. waste gate at 7 and still haven't seen 7 psi. what am I doing wrong?
Old 06-09-2008, 01:22 PM   #20 (permalink)
95gto's Avatar
Drives: 95' VR4
Please make sure that the unit is on. Since it is a gauge it always lights up and displays a reading but you have to tell the unit what mode you want it to run in, A or B. You can adjust the boost settings for both modes all you want with the unit off and you will not see any change in output. The default boost mode for the controller is "off", so you want to make sure you have it set to either A or B.
