Torque Specs - Head Bolts - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 06-15-2005, 11:25 PM   #1 (permalink)
RedDragonVR4X3 is an unknown quantity at this point
Feedback Score: 0 reviews
Default Torque Specs - Head Bolts
I need torque specs for head bolts. I heard it was 90 ft/lbs in a certain order. What about the 12mm bolts on either end of the heads? There are 2 on each end of each head. Do these need to be torqued? If so, how much? Then I will put on the valve covers, which I will be using an in/lb wrench for. After that I need to put on my upper plenum. Any torque specs I should know for that? I am rebuilding an engine with very little previous experience...help me do it right. Also, this is a 3.15 liter TT. Thanks.
RedDragonVR4X3 is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 03:08 AM   #2 (permalink)
Banned from Classifieds
doctorstupid's Avatar
Drives: 95 Subaru Shitbox
doctorstupid is an unknown quantity at this point
Feedback Score: 37 reviews
Default Re: Torque Specs - Head Bolts
The 10mm allen bolts that hold the head on need to be torqued to 90lb.ft. in a criss-cross pattern in three steps. I do 30-60-90 starting from the inside out and never doing two adjacent bolts in order. Then you need to heat-cycle the engine (get it up to full operating temp) and let it cool completely overnight, then retorque the headbolts as they may have loosened. For some added insurance, repeat that step. If you're way into over-kill, like me, do it again.
doctorstupid is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 03:36 AM   #3 (permalink)
Drives: 93 3000GT VR4
Lucky31337 is an unknown quantity at this point
Feedback Score: 8 reviews
3.15L? Did you have the block sonic wall tested? I mean the cylinder to jacket clearences gotta be crazy small.
Lucky31337 is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 03:38 AM   #4 (permalink)
They are! that's 0.120" overbore, not fucking around. I settled for the 080 overs not wanting to mess with scarey thin walls. That and 3100GT sounds better than 3150GT
Old 06-16-2005, 03:47 AM   #5 (permalink)
Personally, I would rather have the stronger walls, I think 3.1L is ok, but 3.15L! the difference in the two is roughly 50 over the 3.1L
Old 06-16-2005, 08:09 AM   #6 (permalink)
Sorry about that, it was late and I was trying to figure out how much .080 over is. So yes, I have a 3.1L and not a 3.15L. Anyway, how about those 12mm bolts on the ends? Do those need to be torqued at all? Gotta know before I slap on the valve covers.
One more question. My oil pan bolts wouldn't hand-tighten so I had to use a ratchet. Because of this, they may be too tight since they are only supposed to go to 5 ft/lbs. Will this cause my oil pan to crack?
Old 06-16-2005, 08:15 AM   #7 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
cbatters is an unknown quantity at this point
Feedback Score: 12 reviews
Kind of crazy to do an engine rebuild without a service manual. You can get bits/pieces of data at www.stealth316.com or order a manual on CD for $35.
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
cbatters is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 04:18 PM   #8 (permalink)
What 12mm bolts on the ends? The only ones I'm seeing are the cam caps...
Old 06-16-2005, 04:54 PM   #9 (permalink)
cbatters's Avatar
("ends" = cam caps???)
still seems like suicide to attempt a rebuild without a manual / specs in hand.
Old 06-16-2005, 06:06 PM   #10 (permalink)
Im confused. Doctorstupid = RedDragonvr4?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
