Old 04-17-2008, 11:04 AM   #1 (permalink)
thatkidfishvr-4 is an unknown quantity at this point
Default test pipe???
Test pipe on my 95vr4 w/stock exaust? good idea? bad idea?
whats some ups and downs?
thatkidfishvr-4 is offline   Reply With Quote
Old 04-17-2008, 11:50 AM   #2 (permalink)
Default Re: test pipe???
anyone?....
Old 04-17-2008, 11:53 AM   #3 (permalink)
Drives: 1995 3000GT VR-4
Geese is an unknown quantity at this point
Good idea if you are getting a downpipe and a catback. Also if your emissions are flexible in your state.
Overall it will free up the exhaust from the restrictive stock cat thats there.
So good idea.
Geese is offline   Reply With Quote
Old 04-17-2008, 11:53 AM   #4 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P is an unknown quantity at this point
Pros: Little more power in the upper end, Slightly faster spool.
Cons: Makes car louder, Makes it no longer "legal" for emissions.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway.
L_P is offline   Reply With Quote
Old 04-17-2008, 11:54 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Great idea if you don't need your catalytic converter. Great idea also to replace it with a downpipe that eliminates your front precat and main cat.
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 04-17-2008, 12:23 PM   #6 (permalink)
any idea where to get a downpipe for a good price?
Old 04-17-2008, 12:29 PM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
Ebay or any of the supporting vendors on here.
Old 04-17-2008, 12:48 PM   #8 (permalink)
k thanx
