Stuck at 6PSI... - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 11-19-2012, 03:22 PM   #1 (permalink)
92STLRTTT is an unknown quantity at this point
Feedback Score: 0 reviews
Default Stuck at 6PSI...
OK i have a 1992 (95 engine swap), vacume reduction was done with a MBC. my car seem to be stuck at 6 psi and wont go any higher. ive checked both turbs and they both are still in working condition. All intercooler piping is hooked up and clamped down, all the silicone hosing from the reduction is all secured, the wastegates actuaters are all secured and no play. i cant figure it out. any ideas ?
92STLRTTT is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:32 PM   #2 (permalink)
caboose's Avatar
Drives: 92 VR4
caboose is an unknown quantity at this point
Feedback Score: 13 reviews
Default Re: Stuck at 6PSI...
Are you positive you have the boost controller hooked up properly?
'92 VR4 - Restoration in Progress
'13 FZ6R
'15 Diavel
caboose is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:35 PM   #3 (permalink)
im pretture sure. un less i put it on backwards and didnt realize it. ill get a picture of it. idr the name of the controller. its one of those bigger ones that holds up to 35psi.
Old 11-19-2012, 03:58 PM   #4 (permalink)
Might as well burn money
lparrill's Avatar
Drives: Duramax
lparrill is an unknown quantity at this point
Feedback Score: 11 reviews
Manual boost controller or electronic
Levi
04.5 Duramax LLY - Built Motor, 72mm VGT/83mm Compounds, 100% over injectors, etc.
69 Mach 1
93 Legacy Turbo - 07 WRX TMIC, MBC
lparrill is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 04:14 PM   #5 (permalink)
lparrill's Avatar
Drives: Duramax
Can't boost over 5 psi
Old 11-19-2012, 04:36 PM   #6 (permalink)
Manual. i just took it for a drive and it went up to 7 now but didn't go any higher any other time or back to 7 . i wonder if the mbc isnt working right.....
Old 11-19-2012, 04:41 PM   #7 (permalink)
thats the MBC i have. ive checked it all so un less im missing something, it all seems to be in workign condition. idk what else to check lol
Old 11-19-2012, 09:06 PM   #8 (permalink)
lparrill's Avatar
Drives: Duramax
Pull your boost reference line for your boost controller (usually y-pipe nipple) and cap it. Now test drive your car but be careful because your wastegates won't open and you'll have to control boost by the throttle. It will spike 22-23psi if you let it. If you can get over 7 psi with closed wastegates then you're problem is your boost controller.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
