**stock 93 vr4 boost controller at 14psi is it safe to run without a wideband??** - 3000GT/Stealth International Message Center
Old 01-14-2013, 03:06 AM   #1 (permalink)
1993vr4life is an unknown quantity at this point
Feedback Score: 0 reviews
Mitsubishi **stock 93 vr4 boost controller at 14psi is it safe to run without a wideband??**
I have a 1993 vr4 bone stock with a boost guage and boost controller i have been running at 14 psi without any fuel cut but was wondering how safe is it to run this way without knowing my afr should be careful and get a wideband or will the car handle it?? thanx !
1993vr4life is offline   Reply With Quote
Old 01-14-2013, 03:21 AM   #2 (permalink)
Just a TT's Avatar
Drives: 93 VR-4
Just a TT is an unknown quantity at this point
Feedback Score: 14 reviews
Default Re: **stock 93 vr4 boost controller at 14psi is it safe to run without a wideband??**
Going to want a logger.
Especially if boost is higher than stock at all...
I personally would back it off to 12 psi to be safe. You are likely seeing some knock at 14, even with a REALLY healthy 93.
1993 Sandstone VR-4
Purchased 1/29/11
50k miles
M2 Turbo-back Exhaust, K&N FIPK, AEM UEGO, AEM Digital Boost Gauge, EGR Blockoffs, 2-piece Aluminum Driveshaft, IPO MBC @ 13psi, DSM Sidemounts, 3sx Pre-Turbo Intake Pipes, DNP Hardpipe Kit, HKS SSQV, Tein S Tech, MP Control Arms, 3sx Clear Turns, 18x9.5" Rota P45R, 2G Brake Conversion, R1 Concepts Drilled and Slotted Rotors, Solid shifter bushings, and mint interior
SOLD 1/20/11
1991 Stealth RT/Twin Turbo
99k miles
408 awhp and 451 awtq @ 16 psi
MHI 13G's, E85, AEM EMS, Greddy Profec B Spec II, Ross pistons, Walbro 255, 750cc RC's, Tanabe Concept G Blue TBE, K&N FIPK, and much more
Just a TT is offline   Reply With Quote
Old 01-14-2013, 07:17 AM   #3 (permalink)
mtonkin6's Avatar
Drives: 92 GTO TT
mtonkin6 is an unknown quantity at this point
Wideband not so important the factory Ecu will take care of the afr all the way to fuel cut. Mine was at around 19psi peak(wastegate line had come off)More important is a datalogger to monitor knock. Up boost till u see knock then go back a psi.
mtonkin6 is offline   Reply With Quote
Old 01-14-2013, 11:38 AM   #4 (permalink)
mas
mas's Avatar
Drives: 95 R/T TT
mas is an unknown quantity at this point
Feedback Score: 4 reviews
back it to 12. untill you hot wire the fuel pump.
then i would try 14. not a PSI more untill you get a logger.
1995 RT TT Galaxy white Pearl. 1 intercooler delete. 1 exhaust delete. More fuel
If SHTF, I want to be out of the room before then.
mas is offline   Reply With Quote
Old 01-14-2013, 01:42 PM   #5 (permalink)
10-4 thanx for all the info will do! makes me feel much safer now im gunna turn it down today until i get a logger!
